greghlondon
BT sockets and fiber
Hello,
We have just bought Virgin Media fiber and got it setup with the quick start installation. We found out that our rented flat (which we can't go drilling holes in) has BT sockets in each room (we initially mistook these for RJ45 Ethernet ports). Can we get an engineer to transfer these to RJ45 connectors or does it require total rewiring? Or can the engineer do that too with permission of the landlord?
  • 22.23K
  • 846
  • 3.23K
Re: BT sockets and fiber
you need a coax cable back to the vm network. the internet is not supplied over rj45. the engineer should of come to install the cabling (with permission of the landlord)
  • 1.33K
  • 89
  • 220
Knows their stuff
Even if you wanted to put Ethernet cables in every room, wired back to a router/switch it would not be just changing the faceplate. Telephone wires while solid like Ethernet cables are only 4 wires, loosely twisted together, whereas Ethernet cabling are 8 wires (white/orange, orange, white/blue, blue, white/green, green, white/ brown, brown) with each coloured "pair" tightly twisted together.
There are 10 types of people: those who understand binary and those who don't
greghlondon
Sorry, I should have said that the internet works fine, it's not an issue of supplying the internet to the box, it's an issue of extending the internet through to other rooms.
greghlondon
Ok thanks. I'll call them up and ask if an engineer can be called in to replace the cabling.
  • 20.74K
  • 554
  • 3.21K
Sephiroth
VM won't put Ethernet into every room (if I've understood you correctly). Tudor above has more or less explained why.
The only way I can see of putting Ethernet into multiple rooms id by the use of Powerline adapters.
