tony_mcv
Message 1 of 5
BT 200 Extenders not working with Superhub 2ac
I am attempting to connect the BT 200 extenders to my Superhub 2ac. The problem I am getting is,
I am not getting an IP address from the router. I have the 1st plug into my Superhub, and the second one connected in the same room to a laptop. I get the message:
does not have a valid ip configuration
I have tried a different set of plugs, and get the same result.
Also, I forgot to mention, the wired connection from the Superhub to the same laptop wired directly, works fine.....and
tested both cables this way with issue.
Tony
Helpful Answers
  • 20.77K
  • 558
  • 3.22K
Sephiroth
Message 3 of 5
Re: BT 200 Extenders not working with Superhub 2ac
Presumably the two Powerline adapters have been sync'd; i.e. they talk to each other?
It is also possible that the IP address of the hub on the laptop has not been released. You could try the command line IPCONFIG/RELEASE followed by IPCONFIG /RENEW and see if that works.
All Replies
tony_mcv
Message 2 of 5
sorry, type:
last line should read - tested both cables this way without issue.
  • 20.77K
  • 558
  • 3.22K
Sephiroth
Message 3 of 5
tony_mcv
Message 4 of 5
Hi all,
The problem appeared to be that these plugs, second hand borrowed, needed to be factory reset
(press button on each for 15-20 seconds)
Luckily, these had the option for that, unlike the first pair I tried.
Many thanks to all that replied !!!
Tony
  • 20.77K
  • 558
  • 3.22K
Sephiroth
Message 5 of 5
Well done.
