  • 362
  • 16
  • 83
pyrotenax
Fibre optic
Message 1 of 23
BQM (Broadband Quality Monitoring) Graph , whats going on here then ?
f403560d66e1a5d237a13eefa3250418-06-01-2017
Vivid 300 connection and Hub 3.0 ... its looking a bit "spikey".
How can the latency be reduced ?
Running ASUS RT-AC88U with Asuswrt-Merlin firmware
  • 20.76K
  • 556
  • 3.22K
Sephiroth
Message 2 of 23
Re: BQM (Broadband Quality Monitoring) Graph , whats going on here then ?
That's bad. The green bit should be around the 15 ms mark and the blue bit (average latency) should be down below the 20 ms mark (as is the case on mine).
The VM bods need to tell you if there is congestion in your area (maybe not looking at your speeds), or if there is a line impairment (again, not evident if those are your regular speeds).
  • 362
  • 16
  • 83
pyrotenax
Fibre optic
Message 3 of 23
Speeds seem fine ..
YorkYorkYork ManchesterManchesterManchester NewcastleNewcastleNewcastle
I do have a HDU-400 on the line .. if that makes any difference ?
  • 20.76K
  • 556
  • 3.22K
Sephiroth
Message 4 of 23
Maybe then you should post the modem power levels (CHECK ROUTER STATUS)
The amplifier is passive and shouldn't affect latency. Maybe also your stats if the HUD is not in line as well as a BQM.
  • 362
  • 16
  • 83
pyrotenax
Fibre optic
Message 5 of 23
  • 13.16K
  • 377
  • 1.08K
Moderator
Moderator
Message 6 of 23
Hi pyrotenax,
Thanks for the info, downstream power levels look a touch on the high side, I'd like to run a few real time checks from this end, though as your last post wasn't from your home connection I've been unable to locate your account.
Drop us a quick update from home and we'll gladly run some further diagnostics on your service from here.
Cheers
Ralph_R
Forum Moderator
  • 362
  • 16
  • 83
pyrotenax
Fibre optic
Message 7 of 23
Ralph_R wrote:
Hi pyrotenax,
Cheers
Thanks for your reply Ralph_R, what further info would you like me to supply you with ?
Here is my current BQM graph
4621e311b954c56cc6bbeea0c62851c3
Cheers
  • 514
  • 27
  • 121
deviousiphone
Rising star
Message 8 of 23
Is it me or does this Puma CPU issue on the Hub3 seem to affect people differently some are bad some are horrendous
  • 1.35K
  • 89
  • 225
Knows their stuff
Message 9 of 23
It gets worse with the member of downstream channels you are on, you are on the max of 20 so you get the highest.
There are 10 types of people: those who understand binary and those who don't
  • 9.42K
  • 316
  • 1.02K
Message 10 of 23
Hello pyrotenax
Thanks for getting back, now you have posted from your home connection we have managed to identify you.
As Ralph mentioned power levels to the hub on the higher frequencies are a bit too high so best we let an engineer take a look and take it from there. I will send you a forum private message to arrange an appointment, please reply when you have a moment.
Incidentally it looks like you are in modem only mode with your own router, possibly Asus? I did try to traceroute/ping your WAN IP to see if I could see where the delay started but got no response, have you turned off ICMP responding? I wonder if it is worth popping the hub into router mode to see what the BQM looks like (your IP will change so you will need to update BQM if you try it by the way)
Thank you
Nicola
Virgin Media Forum Team
