ginettaG15
Auto Compatibility versus Auto Performance
What's the difference between Auto Compatibility and Auto Performance in the 5GHz settings? Which is recommended?
Helpful Answers
  • 20.53K
  • 542
  • 3.16K
Sephiroth
Re: Auto Compatibility versus Auto Performance
If you know that all your connecting devices are modern (2013 & later) thus supporting the 802.11a/n/ac standard, then you can set it to auto-performance.
If not, then auto-compatibility will disallow channel bonding and a few other functions that, e.g. 2009 5GHz devices might not handle.
Something like that.
All Replies
  • 20.53K
  • 542
  • 3.16K
Sephiroth
ginettaG15
Thanks for that. I had assumed I might find an explanation in one of Virgin's bits on improving your wifi performance, but I realise that was a pretty stupid assumption.
  • 20.53K
  • 542
  • 3.16K
Sephiroth
Indeed - and some of the info they do provide is plain wrong.
