  • 8
Tiggy777
Applie Ipad drops wifi after a few minutes
Hi all
It was appear that since upgrading to IOS 10 my wifi on my Ipad keeps dropping after a few minutes.
Did all the normal resets including factory but problem is still there.
Other Ipads / Mac Books in the house all work fine.
Just seems an issue for me.
Any ideas...
Thanks for your help and time
Mike
  • 1.87K
  • 175
  • 338
J0hn
Super solver
Re: Applie Ipad drops wifi after a few minutes
I had this issue on my daughters iPad,
First ensure you are up to dated on the software..... settings, general, software update then
Erase the network that gives you problems with connectivity. Tap "Settings" and "Wi-Fi." Select the desired network and then tap "Forget this Network." This option erases the settings for this network, so you need to re-enter them.
Reset the settings for all the networks on the iPad if the problem persists. Tap "Settings," "General" and "Reset." Tap "Reset Network Settings." Re-enter the configuration information for each network.
Restart the iPad after renewing your IP address or resetting the Wi-Fi network settings. To restart the iPad, hold down the "Sleep/Wake" button. When the red slider appears, slide it to turn off the device. Hold the "Sleep/Wake" button again to turn on the iPad.
I needed to use all the above to resolve it, good luck
  • 2.62K
  • 209
  • 799
Dave_cq
Trouble shooter
Hi Tiggy,
Is your iPad up to date with version 10.0.2 ?  My iPad Pro 9.7" is rock solid on internet connection, never misses a beat.
********* SuperHub 2ac - Asus rt-ac68u Router - Vivid 100Mbps **********
Electron
  • 8
Tiggy777
Thanks for the advice .
Think I have done most of the above but based on your reply I will go through it again.
This only started to be an issue since upgrading to version 10 ? ?
Mike
  • 8
Tiggy777
Tried all of the above but unfortunately problem is still there.
Only get the problem when connecting to the superhub2
Mike
  • 9.99K
  • 294
  • 625
Hey Tiggy777,
Thanks for keeping your post up to date.
Sorry to hear that your problems are on-going. Are you having difficulties with any other devices when connected to your wireless network?
Have you tried changing the operating wireless channel yet?
Hope to hear back from you soon,
Take care.
Heather_J
