Gobbo
Another wifi dropout issue
I have been working from home for a while on a laptop connected via wifi and noticed my connection appears to drop often.  I didn't think this was a big issue, thinking it was the works network.  However, since I have been using some apps on my phone and playing the odd game or two on the desktop, I can see this occurs a number of times per day.
I've changed the channel on the network a number of times as there are a few that aren't being used near by.  I mainly use the 2G due to signal strength, but the 5G also has issues.  I've even sat in the room directly opposite the router, less that 5 meters away and the problem still occurs.  I was hoping someone could see if there were any issues from the following logs:
Network Log:
First Time Last Time Priority Error Number Description
10/02/2017 10:43:50 GMT 10/02/2017 10:43:50 GMT Warning (5) 66050310 Auth Success - Web login successful.
10/02/2017 10:43:40 GMT 10/02/2017 10:43:40 GMT Warning (5) 66050300 Auth Fail - Web login failed.
10/02/2017 00:32:20 GMT 10/02/2017 00:32:20 GMT Critical (3) 82000200 No Ranging Response received - T3 time-out
08/02/2017 13:51:23 GMT 08/02/2017 13:51:23 GMT Error (4) 68010302 DHCP WAN IP -
08/02/2017 13:50:32 GMT 08/02/2017 13:50:32 GMT Error (4) 68000407 TOD established
Time Not Established Time Not Established Notice (6) 84000510 Downstream Locked Successfully
06/02/2017 06:42:23 GMT 06/02/2017 06:42:23 GMT Error (4) 68010302 DHCP WAN IP -
06/02/2017 06:41:50 GMT 06/02/2017 06:41:50 GMT Error (4) 68000407 TOD established
06/02/2017 06:41:40 GMT 06/02/2017 06:41:40 GMT Critical (3) 82000200 No Ranging Response received - T3 time-out
06/02/2017 06:41:38 GMT 06/02/2017 06:41:38 GMT Critical (3) 82000200 No Ranging Response received - T3 time-out
06/02/2017 06:41:37 GMT 06/02/2017 06:41:37 GMT Critical (3) 82000200 No Ranging Response received - T3 time-out
06/02/2017 06:41:31 GMT 06/02/2017 06:41:31 GMT Notice (6) 84000510 Downstream Locked Successfully
02/02/2017 22:22:39 GMT 02/02/2017 22:22:39 GMT Error (4) 68010302 DHCP WAN IP -
02/02/2017 22:21:48 GMT 02/02/2017 22:21:48 GMT Error (4) 68000407 TOD established
02/02/2017 07:21:06 GMT 02/02/2017 07:21:06 GMT Error (4) 68010302 DHCP WAN IP -
02/02/2017 07:20:32 GMT 02/02/2017 07:20:32 GMT Error (4) 68000407 TOD established
02/02/2017 07:20:19 GMT 02/02/2017 07:20:19 GMT Critical (3) 82000200 No Ranging Response received - T3 time-out
02/02/2017 07:20:16 GMT 02/02/2017 07:20:16 GMT Critical (3) 82000200 No Ranging Response received - T3 time-out
Downstream:
  DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz) 283000000 267000000 275000000 291000000 299000000 307000000 315000000 323000000
Lock Status(QAM Lock/FEC Sync/MPEG Lock) Locked Locked Locked Locked Locked Locked Locked Locked
Channel ID 31 29 30 32 33 34 35 36
Modulation 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM 256QAM
Symbol Rate (Msym/sec) 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000 6.952000
Interleave Depth I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
I=12
J=17
Power Level (dBmV) 8.05 8.18 8.06 7.91 7.95 7.81 7.73 7.92
RxMER (dB) 36.84 36.61 36.61 36.17 36.84 36.61 36.61 36.61
Pre RS Errors
178086 178204 177000 176476 167250 167516 167229 167808
Post RS Errors
69209 68814 68953 68610 59842 58374 60663 62125
UpStream:
Upstream   US-1 US-2 US-3 US-4
Channel Type 2.0 N/A N/A 2.0
Channel ID 2 N/A N/A 1
Frequency (Hz) 31000000 N/A N/A 37600000
Ranging Status Success Other Other Success
Modulation 16QAM N/A N/A 16QAM
Symbol Rate (Sym/sec) 5120000 N/A N/A 5120000
Mini-Slot Size 4 N/A N/A 4
Power Level (dBmV) 42.50 N/A N/A 44.50
T1 Timeouts 0 0 0 0
T2 Timeouts 0 0 0 0
T3 Timeouts 1 0 0 0
T4 Timeouts 0 0 0 0
I'm not sure if there is anything else I can provide.
 [MOD EDIT: Personal and private information has been removed from this post. Please do not post personal or private information in your public posts. Please review the Forum Guidelines]
  • 11.02K
  • 324
  • 670
Re: Another wifi dropout issue
Hi there Gobbo,
Thanks for posting and a big welcome to the community Smiley Very Happy
Sorry to hear about the wireless connection problems you're experiencing, I know how frustrating this can be.
I've just taken a look and I've noticed that there's currently an open maintenance ticket present in your area. As a result of this you might notice that your connection is intermittent but this should be resolved by around 4PM this afternoon. Would you please post back to us in a day or two with an update, this maintenance might do the trick, but if not we will happily investigate further.
I appreciate your patience,
Take care.
Heather_J
Gobbo
Hi, thanks for responding to my question. However the problem still exists. It has been there for a while.
However, I have 2 places in the house where wifi doesn't reach, so to fix that issue I bought a Netgear Orbi which has resolved that issue and I also get fantastic wifi speeds all over the house.
It also appears that going via the Orbi network my dropout issue has also been resolved.
So thank you again for your time, but I will just not bother using the Virgin Wireless now.
  • 11.02K
  • 324
  • 670
Hello Gobbo,
Thanks for the update Smiley Happy
It's good to know that you've noticed a significant improvement by using a 3rd party router. I do apologies that your Hub wasn't able to provide the coverage throughout your home.
Appreciate you keeping in touch.
Thanks again.
Heather_J
