nickdubber
Android items drop wifi signal
I have several android items which use the wifi i.e. Tablets and lap tops and a kindle. They are always dropping the wifi signal then you have to manually re connect them back on again. I have an iPad and iPhone never have a problem with these items.
Any ideas
  • 8.81K
  • 1.2K
  • 3.58K
Re: Android items drop wifi signal
Not sure what the issue could be.
I have an android device which automatically connects to the strongest VM WiFi signal from my hub or poweline extension depending on where i am at home as well as connecting to VM WiFi when out and about where available.
_________________________________________________________
Graham
I am a VM customer. There are no guarantees that my advice will work. To say thanks click the kudos thumb. If I have solved your problem please click the helpful answer button.
