  • 232
  • 42
fergiet
Superfast
Amazon Echo Dot and Superhub issues.
The Amazon Echo Dot and Virgin superhub do not always get on together. My Hub2 seemed to cause the Dot to crash when connected to a bluetooth speaker.
Others on here have had the same issues. Some report it's ok with the Hub3.
My solution was to put the Hub2 into modem mode and use a router for wifi. Easy to do.
My wifi is now stronger and no issues so far with the Dot attached to a bluetooth speaker. It just plays as it should. Time will tell, but so far so good.
So if you are having issues it's worth a try.
  • 1.29K
  • 65
  • 236
Knows their stuff
Re: Amazon Echo Dot and Superhub issues.
It's amazing how many issues are fixed when using the SH's in Modem Mode Smiley Wink
I've been using Modem Mode for years ............
