Dhanusms
Access point Issue
Hi all,
I got superhub 3 last week & it doesn't cover my bedroom with a good wifi signal. Then I bought zyxel nwa5121 AP & ran an cat5e cable to it & place it upstairs.
Issue here is I cannot login to zyxel. IP address shown is 192.168.0.37 but cannot access. I also have a netgear switch & I can login to it by entering IP address.
Any suggestions?
Thanks in advance.
  • 16.52K
  • 1.38K
  • 3.38K
Re: Access point Issue
hiya @Dhanusms welcome to the virginmedia community forum, if you plug direct into the zyxel nwa5121 AP can you then access it? since reading the manual quickly says -> browse to https://192.168.1.2 this might have issues since the hub works on the subnet 192.168.0.x
Dhanusms
Hello paultechy,
Thanks for your interest.
I tried connecting it directly but no luck.
Same thing with 192.168.1.2 as well. Couldn't connect
Dhanusms
When I ping the address 192.168.0.28 on cmd prompt. No data loss.
