  • 8
emlrdag
A few issues/faults on my WM superhub2
I am having a few issues with my VM superhub2 :
- The WPS button does not work, and seems to stay pushed in
- I lose ethernet connectivity on one of the ports occasionally, that only seems to come back with a reboot of the hub
- the 5G SSID disappears, and again only returns after a reboot
Are these common problems?
Can they only be resolved with a new unit?
  • 10.82K
  • 308
  • 632
Re: A few issues/faults on my WM superhub2
Hi emlrdag,
Thanks for taking the time to post on the community.
Sorry to read you are having an issue with your broadband connection/router.
With the WPS button this should only be a push in/push out button, if it has stayed pushed in that is an issue with the router itself. Also due to the other issues you have mentioned, I would like to send you a replacement router. If you can send me a Private Message confirming your name and address please, I can order this for you.
Look forward to hearing from you
Sam
