  • 8
gordon217
Message 1 of 13
9.1.116V Home Hub 3.0 ethernet Dropping
Help please, my Home Hub 3.0 keeps dropping the Ethernet, lights on Ethernet port lit, but no traffic, Wi-Fi still working ? Now got a smart home that is dumb ??????
Phoned Virgin Media, not much help, advised it is cable, swapped out with new Ethernet cable to Switch, up for 10-20min then stops throughput to Ethernet, if you unplug Ethernet and plug it back it all good for another 10min, some must have an answer..
Helpful Answers
  • 1.28K
  • 96
  • 236
stevedh2
Knows their stuff
Message 2 of 13
Re: 9.1.116V Home Hub 3.0 ethernet Dropping
Hi, I assume you've tried different ports on the Hub 3 to see if its might be just one port that is dodgy. Tried connecting it directly to a computer to see if the same happens, and trying to ping it when it does. Factory resetting the Hub.. assuming all those fail then probably a fault in the Hub, for which I'll leave you in the capable hands of VM staff...
  • 8
gordon217
Message 3 of 13
Hi Steven,
reset, tried every port, tried modem mode, direct cable, everything, think doggy new firmware that was deployed this week,
  • 8
gordon217
Message 4 of 13
Update, may have found issue, dropping does not happy as much if I unplug Apple TV forth Generation from Ethernet ???
  • 10.65K
  • 313
  • 656
Message 5 of 13
Hello gordon217,
Thanks for getting in touch, hope you're well Smiley Happy
How are you finding your connection since your last post? Have you still narrowed the issue down to the Apple TV?
Please get back it touch if you need us to test or check anything.
Catch you again soon,
Take care.
Heather_J
bfpt
Message 6 of 13
I'm having this issue but don't have an Apple TV. Everything is the same as it has been since mid last year so looks like an update issue?
Xbox one and my Tivo have had updates but it would affect more people if it was them?
Berenice39
Message 7 of 13
Well I think I have the same problem. Ethernet drops out, tried on both Google and Edge initially thinking it was a problem with one of them. And it has only been happening since I received the new Hub 3. My wi-fi though seems to seize at the same, though I have yet to verify that properly. I even, on the advice of an IT guy, bought a new stack as he thought it was my hard drive on the way out. Will make for an interesting conversation with Virgin. By the look of the chain there are no obvious solutions?
  • 8
gordon217
Message 8 of 13
All sorted, router was swapped out for new Home hub 3.0, I would contact support.
All Replies
  • 1.28K
  • 96
  • 236
stevedh2
Knows their stuff
Message 2 of 13
  • 8
gordon217
Message 3 of 13
Hi Steven,
  • 8
gordon217
Message 4 of 13
  • 10.65K
  • 313
  • 656
Message 5 of 13
Hello gordon217,
Take care.
Heather_J
bfpt
Message 6 of 13
Berenice39
Message 7 of 13
  • 8
gordon217
Message 8 of 13
bfpt
Message 9 of 13
Virgin are sending me another. Till it gets here I have everything on WiFi.
  • 8
gordon217
Message 10 of 13
It has now started again on my New Modem 3.0 replacement.
