  • 39
davsco1973
5G ISSUE COMPLAINT
Wright had enough of this crap now, i want this sorting now, this is causing problems, i dont want no rubbish saying have you checked this have you checked that because the answer is yes i have, 5G will just drop for no reason, cannot connect to the 2G as that does not work, the hub just completely freezes so to speak, also resulting in Sky Q mini box not working as this relies on a 5G connection to stream from the main box, this happens at lease once a day, so virgin i am giving you 24 hours to sort this problem, and before you NO THERE ARE PROBLEMS IN MY AREA, NO THERE IS ARE NO OTHER PLACES I CAN MOVE THE HUB TO APART FROM IN THE BIN, YES I HAVE CHANGED CHANNELS MORE TIMES THAN I HAVE HAD HOT DINNERS, ANNOYED YES I AM, THIS HAS BEEN GOING ON 2 WEEKS TO LONG.
how many times do i have to do this?
SORT IT!
  • 39
davsco1973
Re: 5G ISSUE COMPLAINT
on top of all that, the hub has had to be restarted TWICE today with the same bloody issue 10 minutes ago 17:15 so dont tell there is not a problem because there quite clearly is
  • 39
davsco1973
First Time Last Time Priority Error Number Description
04/01/2017 17:03:37 GMT 04/01/2017 17:03:37 GMT Error (4) 68010302 DHCP WAN IP - removed
04/01/2017 17:02:46 GMT 04/01/2017 17:02:46 GMT Error (4) 68000407 TOD established
Time Not Established Time Not Established Notice (6) 84000510 Downstream Locked Successfully
04/01/2017 16:54:46 GMT 04/01/2017 16:54:46 GMT Error (4) 68010302 DHCP WAN IP - removed
04/01/2017 16:53:55 GMT 04/01/2017 16:53:55 GMT Error (4) 68000407 TOD established
04/01/2017 08:09:54 GMT 04/01/2017 08:09:54 GMT Error (4) 68010302 DHCP WAN IP - removed
04/01/2017 08:09:02 GMT 04/01/2017 08:09:02 GMT Error (4) 68000407 TOD established
This just from today
 [MOD EDIT: Personal and private information has been removed from this post. Please do not post your WAN IP address in your public posts. Please review the Forum Guidelines]
