Ianwelsh
Message 1 of 26
3.0 Hub port forwarding for DVR
Can anyone help please. I am trying to set up port forwarding on a new 3.0 Hub to enable remote access via a DVR to my CCTV camera's. A step by step guide would be useful. The version 2 hub seems simple but the 3.0 has changed the set up format. Thanks
Helpful Answers
  • 16.45K
  • 1.37K
  • 3.36K
Message 2 of 26
Re: 3.0 Hub port forwarding for DVR
hiya @Ianwelsh welcome to the virginmedia community forum, what make/model of DVR do you have?, since within the manual should say what ports need forwarding etc..
just need to do the following
setup static ip address on DVR
record this on the hub settings aka reserve the IP
setup port forwarding
apply/save job done.
reserve ip -> https://www.youtube.com/watch?v=Dr46nhKhHI4 (video not made by me)
port forwarding -> http://help.virginmedia.com/system/selfservice.controller?CMD=VIEW_ARTICLE&ARTICLE_ID=27625&CURRENT_...
dont need to deal with port triggering.
All Replies
  • 16.45K
  • 1.37K
  • 3.36K
Message 2 of 26
Ianwelsh
Message 3 of 26
Hi Paul thanks for the reply, now have managed to establish contact and have got my cameras back!
  • 12
hunkmelvyn
Message 4 of 26
I have the same problem having lost the ability to view my cctv cameras on remote access on my iphone since a hub upgrade to the 3. Can somebody explain to me in plain English and simple terms what I need to do please. When it comes to port forwarding I am lost. Thanks Mel
  • 10.58K
  • 311
  • 653
Message 5 of 26
Hello hunkmelvyn,
Thanks for getting in touch, hope you're well Smiley Happy
Sorry to hear about the problems you're having with your CCTV system since upgrading your equipment. We've got a really helpful guide here on Port Forwarding which you should find is useful.
Let us know if this helps,
Take care.
Heather_J
  • 12
hunkmelvyn
Message 6 of 26
Hi Heather, Thank you for the info i will try this out as i am not that techno minded, tick this tick that is about my limit but i will give it my best shot. Thank you once again.
Mel
  • 12
hunkmelvyn
Message 7 of 26
Hi Heather, I have done everything stated on the info given by you, Filled in appropriate sections and once again its the same as remote access its greyed out. i.e. cannot enable remote access and cannot change the new rule, I can change the last number in the IP address but will not let me apply it. So its back to square one. Sorry for the long winded reply.
Mel
  • 10.58K
  • 311
  • 653
Message 8 of 26
Hey Mel,
Thanks for getting back to me Smiley Happy
Sorry to hear you're still struggling. So just so I'm clear, when you're attempting to apply port forwarding rules, the options are greyed out so you're unable to make any changes?
Hope you had a good weekend,
Take care.
Heather_J
  • 12
hunkmelvyn
Message 9 of 26
Yes that,s right when i put a new digit i.e. the I.P. address i cannot apply as it is greyed out. It is the same if i try to enable remote access. Not having much luck. I wish i upgraded to the new hub.
Mel
  • 12
hunkmelvyn
Message 10 of 26
I meant to say , I wish i never upgraded to the new hub 3. I would like the super hub back, never had any problems.
Mel
