Alexu87
3.0 Hub doesn't reset!
Hi.
I forgot my Hub password, tried to reset it to Factory settings several times, following the steps on the help page, but nothing happens. Anyone with the same problem or any idea what to do?
  • 20.76K
  • 556
  • 3.22K
Sephiroth
Re: 3.0 Hub doesn't reset!
Yeah - you have to fight the thing.
With the Hub 3 on and working, I insert the paper clip hard and hold it there till the front panel lights glitch. Then you know the factory reset has occurred. Can take a whole minute.
