Natee
3.0 Hub WiFi keeps dropping out
Hello
My 3.0 Hub keeps dropping out almost daily and has to be restarted by the switch for it to then have the same problem the same day, could someone help me please?
  • 10.7K
  • 314
  • 657
Re: 3.0 Hub WiFi keeps dropping out
Hello there Natee,
Thanks for joining the forum Smiley Happy
Really sorry to hear about the frustrating issue with your wireless connection. Everything looks good from our end when I test your network so I think a good place to start would be to change your wireless channel. Often doing this will improve the performance of wireless connections, especially if you're experiencing interference.
Are you able to give this a try and let us know if it helps.
Hope you have a great weekend,
Take care.
Heather_J
