Downside
Message 1 of 5
200mbs fibre ?? <1mb d/l : Lost MDD Timeout
Shocking download speed of under 2mb, ok upload of 12mbs; wired to my PC.
Are MDD timeouts a thing? Anyone know why? Or even what they are??
Network logs just full of Lost MDD Timeout serval times a minute. Phone tech support and they a) wanted to screen share and b) couldn't even do that because of the terrible speeds!
It's not always been this bad so I don't see how sending me a new SH3 will help - it must be a physical wiring problem. I don't want to seem ungrateful and all, but..
Lock Status Channel ID Frequency Modulation Rx Power RxMER Pre RS Errors Post RS Errors
Locked13266750000 Hz256 QAM0.5 dBmV 33.6 dB474483220
Locked14274750000 Hz256 QAM0.4 dBmV 32.2 dB1807939257978
Locked15282750000 Hz256 QAM0.4 dBmV 30.6 dB7761684929860140
Locked16290750000 Hz256 QAM0.1 dBmV 31.0 dB773275446819315
Locked17298750000 Hz256 QAM0.1 dBmV 32.2 dB69348645322
Locked18306750000 Hz256 QAM-0.3 dBmV 34.0 dB2584942942
Locked19314750000 Hz256 QAM-0.4 dBmV 34.2 dB1045021725
Locked20322750000 Hz256 QAM-0.6 dBmV 34.3 dB199512074
Will a SH3 fix it?
More to the point, will all my SONOS kit work? I thoguht I read that there were some issues with Sonos & SH3?
Sure sucks when the broad band fails. Might have to start tehtering all my kit to my 4g phone..
Helpful Answers
  • 8.99K
  • 756
  • 1.87K
Message 2 of 5
Re: 200mbs fibre ?? <1mb d/l : Lost MDD Timeout
Your downstream SNR is too low, which looks like a local VM issue. The Hub 3 should make a nice paperweight.
You will need to contact VM for resolution, either by waiting here about a week until a VM Forum Team Member picks up the thread, or give them a call again on 150 from a VM line or 0345 454 1111 for a quicker response, personally, I would wait for a reply from the Forum Team.
All Replies
  • 8.99K
  • 756
  • 1.87K
Message 2 of 5
Durtylinen
Message 3 of 5
I'm on 150mbs (fastest in my area), but otherwise getting same problem.  Rebooting significantly increases download speed, but this soon settles back to the miserable numbers you're showing.  Online test by Virgin says my hardware OK.
Downside
Message 4 of 5
Re: 200mbs fibre ?? <1mb d/l : Lost MDD Timeout [Fixed by magic]
Thanks for the views and posts - someone has fixed something somewhere, because the latest speedtest suggests 250mbs down and 15 up.
Power levels up, SNR still about 35db but error counts in the hundreds, not hundred thousands. Some T3 errors reported in the logs last night at 21:30ish and this morning everything seems hunkey dory.
I know, lucky me / fires up netflix /
Downstream ChannelsLock StatusChannel IDFrequency ModulationRx PowerRxMERPre RS ErrorsPost RS Errors
Locked7218750000 Hz256 QAM2.2 dBmV 35.4 dB304293
Locked8226750000 Hz256 QAM2.2 dBmV 35.4 dB305297
Locked9234750000 Hz256 QAM2.0 dBmV 35.4 dB301301
Locked10242750000 Hz256 QAM2.0 dBmV 35.4 dB959956
Locked11250750000 Hz256 QAM2.2 dBmV 35.4 dB309296
Locked12258750000 Hz256 QAM1.8 dBmV 35.4 dB363362
Locked13266750000 Hz256 QAM1.4 dBmV 35.2 dB417415
Locked14274750000 Hz256 QAM1.1 dBmV 35.4 dB301300
Durtylinen
Message 5 of 5
91 down and 10 up here.  Still less than I'm paying for, but vast improvement.
