  • 60
  • 5
CJS23
Message 1 of 30
200mbps to 60mbps speed drops almost daily now
I have the Hub 3.0 in MODEM Mode using an ASUS RT-AC87U as my router. A problem which used to occur every few weeks has now become almost daily. I get around 220mbps dl and 21mbps upload with no issues. At some random point, I will notice my speed drops to around 60mbps dl but always remains at 21mbps ul.
The only way to resolve it is to power cycle the HUB 3.0.
It now has the latest 9.1.116V firmware but the same issue.
Called Virgin and the operator said she could see an issue with my power levels. We power cycled the router and sure enough, full speed again.
That was last night about 20:00. At 08:00 today it has dropped again!
Could someone please look at my Router Status comparison below and tell me if anything obvious is wrong?
The first set is when all is fine and dandy and the second is when the speed has crashed down to 60mbps. O and the ping changes from ~6ms to ~16ms. If I need to post anything extra just ask and I can do this when I get home from work.
Thanks in advance.
Router Status 22:20 20/11/2016
Cable Modem Status
Item
Status
Comments
Acquired Downstream Channel(Hz)
299000000
Locked
Ranged Upstream Channel(Hz)
46200000
Locked
Provisioning State
Online
Channel
Frequency(Hz)
Power
(dBmV)
SNR
(dB)
Modulation
Channel ID
1
299000000
-6
38.6
256 qam
33
2
323000000
-5.9
38.9
256 qam
36
3
307000000
-6.2
38.6
256 qam
34
4
291000000
-6.4
38.6
256 qam
32
5
275000000
-6.7
38.6
256 qam
30
6
315000000
-6
38.6
256 qam
35
7
283000000
-6.5
38.6
256 qam
31
8
267000000
-6.7
38.9
256 qam
29
9
259000000
-6.4
38.6
256 qam
28
10
251000000
-6.4
38.6
256 qam
27
11
243000000
-6.7
38.6
256 qam
26
12
235000000
-7.2
37.6
256 qam
25
Channel ID
Frequency(Hz)
Mode
Power
(dBmV)
Modulation
Channel Bandwidth(Hz)
Symbol Rate (ksps)
17
46200000
ATDMA
48
64 qam
6400000
5120
20
25800000
ATDMA
48
64 qam
6400000
5120
Operational Configuration
General Configuration
Value
Network access
Enabled
Maximum Number of CPEs
1
Baseline Privacy
Enabled
Docsis Mode
Docsis30
Config file
V42997a858765887c.cm
SFID
51562
Max Traffic Rate
230100000
Primary Upstream Service Flow
SFID
57358
Max Traffic Rate
22000000
Router Status 08:03 21/11/2016
Cable Modem Status
Item
Status
Comments
299000000
Locked
46200000
Locked
Provisioning State
Online
Channel
Frequency(Hz)
Power
(dBmV)
SNR
(dB)
Modulation
Channel ID
1
299000000
-6.2
38.6
256 qam
33
2
323000000
-6
38.9
256 qam
36
3
307000000
-6.5
38.6
256 qam
34
4
291000000
-6.7
38.6
256 qam
32
5
275000000
-7
38.6
256 qam
30
6
315000000
-6.2
38.6
256 qam
35
7
283000000
-6.7
38.6
256 qam
31
8
267000000
-7
38.6
256 qam
29
9
259000000
-6.5
38.6
256 qam
28
10
251000000
-6.5
38.6
256 qam
27
11
243000000
-6.9
38.9
256 qam
26
12
235000000
-7.4
37.6
256 qam
25
Channel ID
Frequency(Hz)
Mode
Power
(dBmV)
Modulation
Symbol Rate (ksps)
17
46200000
ATDMA
48
64 qam
6400000
5120
20
25800000
ATDMA
48
64 qam
6400000
5120
Value
Network access
Enabled
1
Baseline Privacy
Enabled
Docsis Mode
Docsis30
Config file
SFID
51562
Max Traffic Rate
230100000
SFID
57358
Max Traffic Rate
22000000
Helpful Answers
  • 9.36K
  • 800
  • 1.96K
Message 5 of 30
Re: 200mbps to 60mbps speed drops almost daily now
The cable looks ok as it is tri shielded, but I would be more concerned about the F connectors if not pre-fitted, as if not crimped properly can inject noise into your local circuit, affecting your connection and others on the same circuit.
Power levels and SNR look fine now.
Looking at your speeds over time, it does not look like a utilisation problem, but VM will need to take a closer look at the traffic on your local segment to confirm.
Starting a Broadband Quality Monitor here  may shed a bit more light on how your connection is performing You will need to enable Respond to ICMP Echo Requests first in the advanced section of the Hub's GUI.
All Replies
  • 10.82K
  • 308
  • 632
Message 2 of 30
Hi CJS23,
Thanks for taking the time to post on the community.
I'm sorry to read that you are having issues with your broadband speeds.
Looking at your connection, the downstream power levels are too low and for this I would like to book an engineer appointment to adjust these for you. I've sent you a PM (purple envelope icon, right corner) requesting some details.
Hope to hear from you soon
Sam
  • 60
  • 5
CJS23
Message 3 of 30
Thanks for the rapid response, Sam.
Looking forward to the engineer visit and getting this annoying issue resolved.
I'll certainly update the Community once resolved.
  • 60
  • 5
CJS23
Message 4 of 30
Alrighty then. Engineer came on Saturday 3rd December. Informed him that I had purchased a 25 metre cable, and that it was very high quality. Cable is from here
http://www.aerialsat.com/prod/25m-webro-hd100-aerial-satellite-coaxial-cable.html
Also explained that speed dropping occurred on the original Virgin Cable when I had a Superhub 2ac in a different room. Also explained that my speed would remain stable for long period including up to a few weeks on one occasion. I therefore doubt very much that it is related to my cable.
The engineer patronisingly said it was most likely my cable. OK, said I, please provide some measurements by measuring my cable so I can get my money back from the cable supplier (!). He then went to the box on the street and adjusted the power levels. I ran a Speedtest and got 160. I gently pointed out that I was used to a constant 200+ when stable. 160 is normal he said, anyways, your power levels were wrong before and they are all in green now.
As you can see from the Speedtest CSV results below, I turned off the Superhub 3.0 for a few moments, turned back on and have remained at 200+ until yesterday when I noted had gone back down to 124mbps.
In other words, the fix does not seem to be working.
TEST_DATE
TIME_ZONE
DOWNLOAD_MEGABITS
UPLOAD_MEGABITS
LATENCY_MS
SERVER_NAME
03/11/2015 20:09
GMT
160.66
12.12
8
Nottingham
03/11/2015 20:14
GMT
159.79
12.24
11
Nottingham
18/06/2016 09:07
GMT
209.34
12.4
7
Nottingham
25/09/2016 12:31
GMT
42.09
20.67
7
Nottingham
25/09/2016 12:32
GMT
41.95
20.62
7
Nottingham
25/09/2016 13:09
GMT
218.96
21.25
7
Nottingham
05/10/2016 08:57
GMT
218.2
21.22
7
Nottingham
29/10/2016 20:27
GMT
204.91
20.61
8
Nottingham
29/10/2016 20:28
GMT
218.72
21.24
8
Nottingham
30/10/2016 21:13
GMT
83.7
20.97
6
Nottingham
30/10/2016 21:15
GMT
79.72
20.83
9
Nottingham
30/10/2016 21:27
GMT
78.76
21.06
6
Nottingham
30/10/2016 21:43
GMT
81.79
21.12
8
Nottingham
30/10/2016 22:03
GMT
214.47
21.33
6
Nottingham
30/10/2016 22:38
GMT
216.77
21.24
7
Nottingham
30/10/2016 23:43
GMT
219.16
21.21
7
Nottingham
31/10/2016 23:28
GMT
216.83
21.18
9
Nottingham
02/11/2016 06:59
GMT
217.93
21.13
7
Nottingham
04/11/2016 09:05
GMT
85.91
21.05
7
Nottingham
05/11/2016 09:02
GMT
219.12
21.17
8
Nottingham
05/11/2016 10:00
GMT
217.81
21.22
7
Nottingham
05/11/2016 23:59
GMT
218.77
20.96
8
Nottingham
18/11/2016 19:36
GMT
41.69
21.09
7
Nottingham
18/11/2016 20:01
GMT
38.37
21.07
8
Nottingham
18/11/2016 20:04
GMT
35.13
20.95
8
Nottingham
18/11/2016 20:06
GMT
33.57
21.03
7
Nottingham
19/11/2016 23:18
GMT
188.02
20.11
6
Nottingham
20/11/2016 20:09
GMT
39.19
20.67
8
Nottingham
20/11/2016 20:17
GMT
41.67
21.16
9
Nottingham
20/11/2016 20:31
GMT
217.98
21.15
7
Nottingham
20/11/2016 23:10
GMT
218.73
21.15
7
Nottingham
23/11/2016 19:29
GMT
61.77
19.17
7
Nottingham
23/11/2016 19:38
GMT
83.52
20.88
7
Nottingham
23/11/2016 21:03
GMT
218.86
21
7
Nottingham
23/11/2016 22:24
GMT
219.07
21.17
9
Nottingham
25/11/2016 08:49
GMT
219.18
21.21
7
Nottingham
25/11/2016 08:53
GMT
219.06
21.19
8
Nottingham
26/11/2016 20:16
GMT
76
20.93
8
Nottingham
28/11/2016 08:45
GMT
218.39
21.1
7
Nottingham
28/11/2016 21:26
GMT
217.58
21.18
8
Nottingham
30/11/2016 08:52
GMT
217.73
21.12
7
Nottingham
01/12/2016 19:49
GMT
199.43
20.94
8
Nottingham
03/12/2016 08:31
GMT
164.12
20.2
7
Nottingham
03/12/2016 08:35
GMT
169.69
20.04
4
Nottingham
03/12/2016 08:47
GMT
219.03
21.15
7
Nottingham
03/12/2016 08:49
GMT
219.13
21.15
7
Nottingham
03/12/2016 22:01
GMT
218.98
21.22
7
Nottingham
04/12/2016 22:01
GMT
218.98
21.1
7
Nottingham
04/12/2016 22:03
GMT
218.38
21.21
5
Nottingham
05/12/2016 10:47
GMT
219.16
21.23
8
Nottingham
06/12/2016 07:34
GMT
206.84
20.69
7
Nottingham
09/12/2016 22:34
GMT
124.88
21.18
8
Nottingham
09/12/2016 22:35
GMT
124.41
21.24
5
Nottingham
09/12/2016 22:57
GMT
215.94
20.59
6
Nottingham
10/12/2016 17:38
GMT
215.14
21.19
7
Nottingham
Here are my current power levels. Anyone got an idea of what's going on?
Upstream bonded channels5120
Channel ID
Frequency(Hz)
Mode
Power
(dBmV)
Modulation
Symbol Rate (ksps)
17
46200000
ATDMA
42
64 qam
6400000
5120
20
25800000
ATDMA
42
64 qam
6400000
Downstream bonded channels25
Channel
Frequency(Hz)
Power
(dBmV)
SNR
(dB)
Modulation
Channel ID
299000000
-1
38.9
256 qam
33
323000000
-1.2
38.6
256 qam
36
315000000
-1.2
38.9
256 qam
35
307000000
-1.4
38.9
256 qam
34
291000000
-1.5
38.6
256 qam
32
283000000
-1.5
38.9
256 qam
31
275000000
-2
38.9
256 qam
30
267000000
-1.9
38.9
256 qam
29
259000000
-1.5
38.6
256 qam
28
10
251000000
-1.5
38.9
256 qam
27
11
243000000
-1.4
38.6
256 qam
26
12
235000000
38.9
256 qam
25
  • 9.36K
  • 800
  • 1.96K
Message 5 of 30
  • 60
  • 5
CJS23
Message 6 of 30
Hi Griffin
Thank you very much for the reply.
I paid for the ends to be crimped i.e. the cable came crimped from the supplier.
I use my Superhub 3.0 in MODEM Mode in conjunction with my ASUS RT-AC87U whose logs show nothing untoward.
Are there any special instructions for BQM with this setup, please?
  • 60
  • 5
CJS23
Message 7 of 30
Further to my last post, the download speed has now dropped again to 85mbps, upload 21mbps (never drops).
This is with Superhub 3.0 in MODEM mode to my ASUS RT-AC87U. CAT 6A cable direct to router. I have to disconnect to get Router Status from Superhub 3.0. Only way I can connect whilst in MODEM mode is to boot a laptop to Parted Magic, and clone my MAC address to the network card! I then have to log in to OneNote and copy and paste the stats to the cloud so I can come back to the forums and post in a legible format, lol!
As I say, any advice on how to set the BQM monitor up to the Superhub 3.0 in MODEM mode would be appreciated. I'll Google it in the meantime. Thanks for all your continued help, guys. I'm sure you can appreciate how frustrating this all is. Before I became a virgin customer, I would have been more than happy with the speeds I'm getting. However, I'm paying top whack for Vivid 200 and the Full House TV package and as such deserve to consistently get what I pay for. If I had to restart the MODEM once in a blue moon, then fair enough, but having to do this sometimes on a DAILY basis is tiresome.
The next post will be my Router Status stats before power cycling the MODEM and the one after that after power cycling the MODEM.
Cheers
Chris
  • 60
  • 5
CJS23
Message 8 of 30
Before MODEM restart
Hub 3.0 device information
The information below shows the current status of this Hub 3.0.
Standard specification compliant
: DOCSIS 3.0
Hardware version
: 10
Software version
: 9.1.116V
Cable Modem Status
Online
Item
Status
Comments
299000000
Locked
46200000
Locked
Provisioning State
Channel
Frequency(Hz)
Power
(dBmV)
SNR
(dB)
Modulation
Channel ID
1
299000000
-1
38.9
256 qam
33
2
323000000
-1.2
38.9
256 qam
36
3
315000000
-1.2
38.6
256 qam
35
4
307000000
-1.4
38.9
256 qam
34
5
291000000
-1.5
38.9
256 qam
32
6
283000000
-1.5
38.9
256 qam
31
7
275000000
-1.9
38.9
256 qam
30
8
267000000
-1.9
38.6
256 qam
29
9
259000000
-1.4
38.9
256 qam
28
10
251000000
-1.2
38.6
256 qam
27
11
243000000
-1.4
38.9
256 qam
26
12
235000000
-1.5
38.9
256 qam
25
Channel ID
Frequency(Hz)
Mode
Power
(dBmV)
Modulation
Symbol Rate (ksps)
17
46200000
ATDMA
42.3
64 qam
6400000
5120
20
25800000
ATDMA
42.3
64 qam
6400000
Operational Configuration22000000
Value
Network access
Enabled
1
Baseline Privacy
Enabled
Docsis Mode
Docsis30
Config file
SFID
18030
Max Traffic Rate
230100000
SFID
39184
Max Traffic Rate
Network LogNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Date And Time
Error Number
Event Description
2016-12-10 19:17:25.00
82000200
2016-12-10 19:17:26.00
84020200
Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
2016-12-10 19:35:20.00
84000500
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
84000700
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
84000500
2016-12-10 19:35:22.00
84000700
2016-12-10 19:35:23.00
84000500
84000700
2016-12-10 19:35:24.00
84000500
2016-12-10 19:35:25.00
82000200
84020200
2016-12-11 06:26:28.00
84000500
2016-12-11 06:26:29.00
84000700
84000500
2016-12-11 06:26:31.00
84000700
2016-12-11 06:26:32.00
84000500
84000700
84000500
2016-12-11 06:26:34.00
84020200
82000200
  • 60
  • 5
CJS23
Message 9 of 30
And after MODEM restart
: DOCSIS 3.0
Hardware version
: 10
Software version
: 9.1.116V
 Cable Modem Status Online
Item
Status
Comments
299000000
Locked
46200000
Locked
Provisioning State
Online
Channel
Frequency(Hz)
Power
(dBmV)
SNR
(dB)
Modulation
Channel ID
1
299000000
-0.9
38.9
256 qam
33
2
323000000
-0.9
38.9
256 qam
36
3
315000000
-1
38.9
256 qam
35
4
307000000
-1.2
38.9
256 qam
34
5
291000000
-1.2
38.9
256 qam
32
6
283000000
-1.4
38.9
256 qam
31
7
275000000
-1.7
38.9
256 qam
30
8
267000000
-1.5
38.9
256 qam
29
9
259000000
-1.2
38.6
256 qam
28
10
251000000
-1
38.9
256 qam
27
11
243000000
-1
38.9
256 qam
26
12
235000000
-1.2
38.9
256 qam
25
Channel ID
Frequency(Hz)
Mode
Power
(dBmV)
Modulation
Symbol Rate (ksps)
17
46200000
ATDMA
42.3
64 qam
6400000
5120
19
32600000
ATDMA
42.3
64 qam
6400000
5120
Value
Network access
Enabled
1
Baseline Privacy
Enabled
Docsis Mode
Docsis30
Config file
SFID
66507
Max Traffic Rate
230100000
SFID
5843
Max Traffic Rate
22000000
Date And Time
Error Number
Event Description
84000700
84000500
84000700
84000500
84000700
84000500
82000200
84020200
84000500
84000700
84000500
84000700
84000500
84000700
84000500
84020200
82000200
1970-01-01 00:01:26.00
84020200
84020300
MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
1970-01-01 00:01:40.00
82000200
  • 10.82K
  • 308
  • 632
Message 10 of 30
Morning Chris,
Thanks for getting in touch and my apologies that you are still having the same issue.
I've just checked your line, the power levels are within range, there have been no time-outs since the router has been online and there are no apparent issues on the network that I could see that would cause this.
Just for testing, are you able to disconnect your equipment from the Hub and create a Broadband Quality Monitor to check the performance of your connection please? We need to rule out as much as we can to find out what is causing this issue.
Let us know how you get on
Sam
