SkukBlaker
2.4ghz issues
Been having issues connecting any device to 2.4ghz. Nothing will connect to it and even if it does no data comes through. I have firesticks in the house and virgin had to set up a different channel and access for them to use but even now that is buffering like mad when watching Netflix and amazon prime. Using the hub 2 and a power line adapter but speeds are horrendous just now, and ever since moving onto the TV package too.
  • 10.82K
  • 308
  • 632
Re: 2.4ghz issues
Hi there SkukBlaker,
My apologies you are having an issue with the 2.4 GHz wireless network.
I can see you have called through to us to discuss this further.
Have you noticed an improvement with the connection at all or are you still experiencing the same issue?
Hope to hear from you soon
Sam
