Searching for something?
Fresh as a Daisy
nanapopsuk
My phone is running slow, what can I do to speed it up?
Please use plain text.
Rita-B
Re: My phone is running slow, what can I do to speed it up?
Hi nanapopsuk,
Thank you for your post :smileyhappy:
What handset are using?  I would recommend the basic, ensuring your handset is up to date with the latest software.
Check your internal space, move your media (pictures, mp3 files, videos, and so forth) to the external memory, usually an SD card.
I would also recommend clearing the internet cache by accessing settings in the browser as well as clearing the RAM for the phone using the task manager
Also un-install any application which you do not use.
These will help speed up your phone :smileyhappy:
Hope this helps :smileyhappy:
Rita B
Help & Support Forum Team
Seen a useful post?Problem Solved?Fault with your service?
