  • 89
  • 15
SH3user
Up to speed
Speed Boost???
My broadband speed was boosted from 50Mb then to 70Mb then 100Mb when I changed my package. I have tried various speed test sites at various times and the results come out at around 53Meg. I ignored the site that gave a result of 215Meg. How can I confirm that the download speed has increased as ''up to 100Mb'' could still be 50Mb with that wording?
I would like to add that I am not experiencing any speed issues when browsing or gaming and this is just a general question.
  • 16.67K
  • 1.4K
  • 3.42K
Re: Speed Boost???
hiya @SH3user best way to check what speed you're on is to goto http://192.168.0.1 clicking router status top right [no need to login] and if can copy/paste the operational config.
  • 89
  • 15
SH3user
Up to speed
Re: Speed Boost???
Operational Configuration General Configuration Value
Network access
Enabled
Maximum Number of CPEs
1
Baseline Privacy
Enabled
Docsis Mode
Docsis30
Config file
V3c1310bb03cca99.cm
SFID11138
Max Traffic Rate115100000
Primary Upstream Service Flow
SFID63237
Max Traffic Rate6400000
  • 16.67K
  • 1.4K
  • 3.42K
Re: Speed Boost???
yeah your on a 100mb down and 6mb up, when your testing the speed is this via wired/wireless?, since if its wireless depending on distance, hardware etc etc..
