  • 6
fleetville
Message 1 of 15
Cable problem
Hi. While laying some paving slabs in my front garden I uncovered the cable. I didn't damage it but it needs to be buried deeper to avoid future damage. The garden wall  is about 2m from the house.
Helpful Answers
  • 10.33K
  • 1.03K
  • 1.92K
Message 2 of 15
Re: Cable problem
If is a more modern drop, it should be in green trunking, & buried to about a spades depth. A lot of the older drops were laid unprotected. I would have a talk with Customer Services, but there is normally a £99 charge for callouts that are non fault related.
su1718.jpgCable customer since 1993. Services: FH TV, Sky Sports & Movies (2xV6), Talk Anytime Phone, VIVID 350, Virgin PAYG Mobile
All Replies
  • 10.33K
  • 1.03K
  • 1.92K
Message 2 of 15
Re: Cable problem
  • 6
fleetville
Message 3 of 15
Re: Cable problem
Thanks for the advice. I'll contact Customer Services.
  • 94
  • 6
  • 18
AlecEdworthy
Up to speed
Message 4 of 15
Re: Cable problem
Unfortunately that is not always the case.  I had cable installed this week and they appeared to bury the cable from the edge of my property (middle of the grass verge) to the wall running between my garden and that of my neighbour (around a 2 or 3 metre run) without any trunking or other protection, but I would guess it was around a spade's depth (albeit a fairly short spade I'd say).  The box which is supposed to exist in the ground at the edge of my property also came out as they were running the connection so they just chucked that away, shoved a rag into the hole and covered it over with soil instead.  I could be wrong but I didn't see any trunking come out of their van at all and I know they threw the box away because they commented to me about it at the time.
Alec
  • 10.33K
  • 1.03K
  • 1.92K
Message 5 of 15
Re: Cable problem
Some contractors are better than others. The way I have described is the way it should be done. I'm sure the Forum Team will be able to get this fixed if you are not happy with the install. Post some photos if you think this would be helpfull.
  • 95
  • 12
oojimmyflip
Dialled in
Message 6 of 15
Re: Cable problem
Front Gardens especially in modern builds will have electricity cables buried at a shallow depth
sometimes the builders will fill the front garden with hard-core before laying the soil and grass/slabs
if your going to dig deeper be careful you don't hit the electricity meter cable especially if your
meters are on the front of the building.
  • 6
fleetville
Message 7 of 15
Re: Cable problem
As you can see, the trunking is only just under the slab level. Surely this can't be considered satisfactory?
Andy
  • 94
  • 6
  • 18
AlecEdworthy
Up to speed
Message 8 of 15
Re: Cable problem
Andy
You might want to post a slightly larger image (or select a larger size in the attach window) as that one is a little too small to discern much from it.
A
  • 21.02K
  • 771
  • 1.56K
Message 9 of 15
Re: Cable problem
Hi fleetville,
Thanks for your post and apologies for the issues you had with the installation.
As we are unable to look directly into this, I have sent you a private message on where to go from here. Just click on the little red envelope at the top left hand side of the page to access your inbox. Smiley Happy
Kath_F
  • 6
fleetville
Message 10 of 15
Hi. I've had another site visit but the work that was done was not what I wanted
because I didn't have the opportunity to tell the engineer what was needed. I didn't even see him, so he laid another cable on top of the old one!
Can I have another visit to sort this out please?
