Making Waves
chunkyguru
International calls from Virgin landline using www.cheapinternationalcalls.co.uk
How much, if anything, does VirginMedia charge as a "connection fee" for allowing customers to make cheap International calls using companies like Cheapinternationalcalls.co.uk?
Please use plain text.
Boffin
LesleyChenard
Re: International calls from Virgin landline using www.cheapinternationalcalls.co.uk
Hi chunkyguru,
We are a faults forum & as such do not deal with this type of query. This link should provide the information you require.
http://shop.virginmedia.com/phone/calling-costs.html
Regards,
Lesley Chenard
Help & Support Forum Team
Seen a useful post?Problem Solved?Fault with your service?
Making Waves
chunkyguru
Your link does not answer the question, but I found the answer on the MoneySavingExpert site at this web link
http://callchecker.moneysavingexpert.com/intcallchecker/turkey-mobile/virgin/easy
nodrogd
Yes, it does answer your question. You have to look up the prefix in the non-geo numbers PDF and then cross reference to the price list PDF. Takes a little longer but all the info is there. MSE get their info from the very same lists..
Cable customer since 1993. Services: XL TV, Sky Sports & Movies (2xV+), XL Telco, 100Mb BB, Virgin PAYG Mobile
