Ask a question
Fresh as a Daisy
Blocking incoming numbers or changing tel no
How do I block incoming calls from certain numbers that call, day in day out and will not stop calling - sometimes upto 4 calls a day.
If I am unable to block these calls then would there be any charge for changing my tel no as this is the preferable alternative.
Many thanks :smileyhappy:
Fix-a-Lot
Re: Blocking incoming numbers or changing tel no
Hi milliemoo67
Customer care can add anonymous caller rejection to stop anonymous calls or they can give you a number change, I think the number change should be free of charge but best to speak with the team on 150.
Brian_J
Help & Support Forum Team
If someone's helped you out say thanks by clicking on the Kudos Star. If someone's solved your problem, why not mark their message as a Helpful Answer? You can also help other users find useful posts by Tagging them with keywords.
If you are new to the forum, please remember to search the forum before posting your question. Please don't send private messages directly to the forum team unless they ask you to, post your issue to the forum first.
Fresh as a Daisy
Will try giving them a call then.
Thanks :smileyhappy:
Fresh as a Daisy
Ive been getting calls from 08005875290 and everytime I answer they hang up.
So far 5 calls today.
When I google the number other people are saying its a virgin media number all with
different stories to tell.
Is there a way I can block calls from this number now as its been going on for about
2 weeks now.
