• 423
  • 785
Virgin Media Staff
Virgin Media Staff
Message 1 of 1
How do I Fix Sound and Picture Problems on my TiVo®
How do I get rid of the bars on my screen?
These bars could have been added by the TV channel broadcaster, your set top box or TV. To make sure it's not a TiVo setting you'll need to check two of the settings:
Make sure your TV Aspect Ratio is set correctly. Press Home on your TiVo remote, then select Help & Settings > Settings > Video then TV Aspect Ratio. Make sure it's set for the type of TV you have.
When you’re watching older programmes you may find that there are bars down the left and right of the screen.
You can change this for SD channels by changing the Aspect Correction Mode. We normally recommend setting this is set to Panel as this makes sure that all programmes are shown by TiVo without any alteration. If you change this to Full Screen or Zoom the picture is altered to fill the TV screen.
If you’re watching an older programme on an HD channel, you won’t be able to remove the bars, as these are part of the picture received from the broadcaster.
If you can’t make the changes you wish, check your TV’s manual for further picture options.
The picture and sound are out of sync
Try changing channels, then switch back again.
  • Press Back on your remote to try and re-sync.
  • Go to the Home screen, then press TV to go back to live TV.
  • Check that all your cable connections are plugged in properly
If none of these work, Reboot your TiVo® by turning the box off by going to Help & Settings > Clear or Reset TiVo® > Restart TiVo®, and then follow the onscreen instructions
My TV’s picture has frozen?
Try changing channels a few times.
PressPause on your remote, then pressPlay .
If this doesn’t work, restart your Virgin Media TiVo box.
I’m not getting a picture on my TV anymore
See No TV picture when using a TiVo box if you've lost your picture.
No sound on some recordings
If you're getting no sound on recordings from some HD channels when using external sound equipment connected via an optical connection, like an amp or surround sound system, change the audio setting from Dolby Digital to Dolby Digital to PCM.
To change this setting on your TiVo box, press Home on your TiVo remote then select Help & Settings > Settings > Audio > Dolby Digital > Dolby Digital to PCM.
If you have an HDMI input on your external sound equipment, you may find changing to this connection also restores sound.
Recordings from the following list of HD channels may be affected:
HD Channel
Animal Planet
BBC 1 England and Scotland
BT Sports 1
BT Sports 2
BT Sports Europe
Cartoon Net
Channel 4
Channel Five
Comedy Central
Eurosport 2
Film Four
More 4
MTV Live
Nat Geo Wild
Nat Geo Wild
NHK World
Sky Action
Sky Arts 1
Sky Comedy
Sky Crime Thriller
Sky Drama+Romance
Sky Family
Sky Living
Sky Modern Greats
Sky Cinema Disney
Sky Cinema Indie/Select
Sky News
Sky One
Sky Premier
Sky Scifi
Sky Showcase
Sky Sports 1
Sky Sports 2
Sky Sports 3
Sky Sports 4
Sky Sports 5
Sky Sports F1
Sky Sports News HQ
