  • 12
Message 1 of 15 (13,944 Views)
xbox 360 NAT type strict problem
I have just recently joined Virgin Media and encountered a problem with connecting my wireless xbox360 to the super hub, I go through the network settings on my xbox and it says my NAT type is strict, any idea on how to set it to open? I also have a Playsation 3 which connected fine and has an open NAT, please reply!
Dialled in
  • 209
  • 10
Message 4 of 15 (13,992 Views)
confirmed by DannyNumberOne
Re: xbox 360 NAT type strict problem
192.168.0.1 into any browser address bar.
GoTo advanced setup. Then click services, then untick every setting.
All Replies
Dialled in
  • 209
  • 10
Message 2 of 15 (13,925 Views)
[ Edited ]
Are you using the hub??
If so disable the NAT setting all together it affects any gaming activity you do.
  • 12
Message 3 of 15 (13,932 Views)
Yeah I'm using the super hub, how do I disable the NAT setting? my PS3 is connected to the hub without any problems though
Dialled in
  • 209
  • 10
Message 4 of 15 (13,993 Views)
  • 12
Message 5 of 15 (13,931 Views)
I forgot to say my xbox does actually connect but it is on a strict NAT type, which can cause problems e.g. hearing people on headsets, I don't know how to change it to an open NAT type
Dialled in
  • 209
  • 10
Message 6 of 15 (13,932 Views)
[ Edited ]
If this does not work use a youtube video to show you how to port-forward the XBOX. I have done this, and have a stable connection on the PS3.
  • 12
Message 7 of 15 (13,922 Views)
Is it something like NAT filtering that I need to uncheck?, I'm not currently at my house
Dialled in
  • 209
  • 10
Message 8 of 15 (13,919 Views)
Yes, something like that. Untick every setting in the services area.
Dialled in
  • 209
  • 10
Message 9 of 15 (13,916 Views)
[ Edited ]
Make sure you are hard-wired by ethernet to the SuperHub though, while unticking the setting.
  • 12
Message 10 of 15 (13,909 Views)
my xbox is upstairs though, I'm trying to set it up wireless, will it still work if it's not hardwired?
