  • 24
Message 1 of 14 (879 Views)
Xbox 360 Connection/Lag Problems
Over the last few days i have been unable to play any matches on xbox live. I am able to connect to it but the connection speed is very slow and unplayable. I am using 20mb/s broadband speed and have the xbox connected to a Netgear VMDG280. any help on how to fix this would be highly appreciated.
  • 12.34K
  • 856
  • 2.09K
Message 2 of 14 (863 Views)
Re: Xbox 360 Connection/Lag Problems
with your xbox is that wired or wireless to the hub, if its wireless have you tired altering any settings on the hub especially the wireless channel?
If using Netgear VMDG280
Visit http://192.168.0.1 enter password when prompted (This can be found on a sticker on your VMDG280) Click on the Connection and paste the information there. this will show any issues with the signal.
If someone's helped you out say thanks by clicking on the Kudos Star. If someone's solved your problem, why not mark their message as an Accepted Solution
  • 24
Message 3 of 14 (844 Views)
i turned it on today and for the first time in 4 days i am able to play on xbox live. hopefully it stays this way. chrs for your help anyway
  • 24
Message 4 of 14 (765 Views)
[ Edited ]
today it has once again rnadomly disconnected and is now doing it again. this is really starting to **** me off and i cant see why virgin media cant just sort the  problem out. instead of making us do all this rubbish with our hubs they should be fixed and working when we buy them.
  • 24
Message 5 of 14 (759 Views)
TimePriorityDescription
 Fri Oct 29 19:32:17 2010   Warning (5)  Admin login authentication fails
 Fri Oct 29 19:14:42 2010   Warning (5)  Admin login authentication fails
 Fri Oct 29 19:14:33 2010   Warning (5)  Admin login authentication fails
 Time Not Established  Critical (3)  DHCP FAILED - Requested Info not supported.
 Fri Oct 22 15:00:22 2010   Critical (3)  SYNC Timing Synchronization failure - Loss of Sync
 Tue Oct 19 16:38:52 2010   Critical (3)  Started Unicast Maintenance Ranging - No Response received - ...
 Time Not Established  Critical (3)  No Ranging Response received - T3 time-out
 Wed Oct 06 06:02:33 2010   Critical (3)  SYNC Timing Synchronization failure - Loss of Sync
 Tue Oct 05 18:35:48 2010   Critical (3)  Started Unicast Maintenance Ranging - No Response received - ...
 Tue Sep 21 10:28:52 2010   Critical (3)  Started Unicast Maintenance Ranging - No Response received - ...
 Sat Sep 18 13:00:01 2010   Critical (3)  Started Unicast Maintenance Ranging - No Response received - ...
 Fri Aug 27 19:56:09 2010   Critical (3)  Started Unicast Maintenance Ranging - No Response received - ...
 Sun Oct 03 16:21:00 2010   Critical (3)  SYNC Timing Synchronization failure - Failed to acquire QAM/Q...
 Fri Aug 27 12:08:58 2010   Critical (3)  Resetting the cable modem due to docsDevResetNow
  • 24
Message 6 of 14 (758 Views)
what i have just posted is the event log. as you can see there are alot of things failing
  • 24
Message 7 of 14 (738 Views)
can someone please reply. i really am getting sick of waiting on help for this problem.
  • 5.52K
  • 101
  • 364
Message 8 of 14 (677 Views)
Hi RobbieX27
I have taken a look at your local network and can see some very brief spikes in the traffic going through the Cable you're connected to which would cause short bursts of lag once or twice a day.  To see if this times correlates with your issues could you post the date and times the fault occurs and how long the issue lasts for?  Could you also post a trace to the BBC website during a time when the fault is apparent.
Regards,
Lee Grant
Help & Support Forum Team
If someone's helped you out say thanks by clicking on the Kudos Star. If someone's solved your problem, why not mark their message as an Accepted Solution? You can also help other users find useful posts by Tagging them with keywords.
If you are new to the forum, please remember to search the forum before posting your question.
Please can we ask you not to PM the Forum team unless requested to do so by us
  • 24
Message 9 of 14 (615 Views)
it hasnt done it for the last week but it has now done it again today. it will probably last around 2-3 days.
  • 5.52K
  • 101
  • 364
Message 10 of 14 (577 Views)
Hi RobbieX27
If it happens again can you provide dates and times please.
Regards,
Lee Grant
