  • 5
Message 1 of 6 (1,782 Views)
Wireless dongle not working - no lights
I connect my PC to my Virgin Media Superhub using the supplied dongle, but the light on the dongle now fails to come on and it won't connect to my network. When I plug it in I'm asked if I want to open the folder, and I run AutoInst.exe, but although the software reinstalls the dongle still doesn't turn on and see the network. I know the superhub's working because I can connect to it other wireless devices. Is it possible to fix the problem or do I need a replacement dongle (and if so, do I need to pay for that)?
Thanks Smiley Happy
  • 3.89K
  • 75
  • 222
Message 2 of 6 (1,779 Views)
confirmed by essentialatom
‎28-08-2015 00:15
Re: Wireless dongle not working - no lights
Hi essentialatom,
I can see from the notes on your account that you have contacted our technical support team since your last post and that an adaptor has been ordered and sent for you.
The adaptor usually takes a couple of working days to reach you.
When you receive the adaptor could you please test and let us know if this resolves your issue?
Regards,
James Gilbert
Help & Support Forum Team
If someone's helped you out say thanks by clicking on the Kudos Star. If someone's solved your problem, why not mark their message as an Accepted Solution? You can also help other users find useful posts by Tagging them with keywords.
If you are new to the forum, please remember to search the forum before posting your question.
Please can we ask you not to PM the Forum team unless requested to do so by us
All Replies
  • 3.89K
  • 75
  • 222
Message 2 of 6 (1,780 Views)
‎28-08-2015 00:15
Hi essentialatom,
Regards,
James Gilbert
  • 5
Message 3 of 6 (1,755 Views)
Yes, sorry I didn't update this thread. I have received the new dongle and it works perfectly, thank you Smiley Happy
  • 3.89K
  • 75
  • 222
Message 4 of 6 (1,735 Views)
Hi essentailatom,
I am glad to hear the new adaptor has arrived and is working correctly for you.
Thanks for letting us know.
Regards,
James Gilbert
  • 9
Message 5 of 6 (1,510 Views)
hi my dongle has started droping in and out...ive checked my hub with an ethernet and my laptop wifi all good...the dongle seems to have developed a fault...can anybody suggest how to go about getting another one...as this one has or is on its last legs...cheers
  • 1.08K
  • 5
  • 40
Message 6 of 6 (1,492 Views)
Hi diskodog
If you haven't already done so, please post a new thread detailing your difficulties and we'll look into them for you. Piggy-backing onto an existing thread makes it more difficult for us to assist you initially, and to keep track of any developments. Individual threads reduce the chances of a post 'slipping through the net'.
Kind Regards,
Luke Thomas
