Message 1 of 11 (419 Views)
Wireless PC to TV.... How to?
Hi I'm a bit new to this sort of thing:
I have:
windows 7 64 bit
Toshiba 50" HDTV
Virgin Media Netgear Wireless N Cable Gateway
How do I connect these both together wirelessly and what do I need.
I have the HDTV cable but its not long enough and I don't want wires all around my house so thought this was the best option.
I need it for my photography & videos
Any help would be appreciated, please can you keep the jargon down so I can follow Smiley LOL
Marie
A partner is for life not just for christmas!!
All Replies
  • 24
Message 2 of 11 (402 Views)
Re: Wireless PC to TV.... How to?
[ Edited ]
i think the bestway is powerline you can  get either wireless or wired variants but your tv would need a wireless adapter if it isnt wifi enabled and i have no idea how to get wireless adapaters for tvs
so best option would be a wired powerline set up which means some wires but not all round your house
if you go to virgin media.com tab above and go into the pc and then home networking theres a few powerline adapters that virgin recomends but you can go on ebay and get them cheaper but your home wiring needs to be decent condition  for decent speeds thats the only option i can think of for not running wires all over your house  hope this helps Smiley Happy  its also recomended you plug powerline directly into a wall socket and not an adapter for the best speeds
  • 9.28K
  • 423
  • 2.24K
Message 3 of 11 (387 Views)
I have:
windows 7 64 bit
Toshiba 50" HDTV
Marie
Hi Marie
When you say you want to connect the PC wirelessly to the TV - is that to view the PC on your TV screen or simply to access the network resources?
I ask as you mentioned having the HDTV cable in your post.
Ravenstar68
________________________________________
Only use Helpful answer if your problems been solved.
Message 4 of 11 (366 Views)
I want it to view my pc screen so I can watch videos I make and show photo and stuff like that... suppose it would be like another monitor.... I want to be able to access my pc files etc... hope that makes sense.
sorry I meant to say HDMI cable not HDTV cable... but the HDMI is too short to run from pc to tv Smiley Surprised
Message 5 of 11 (365 Views)
Thanks I will have a look at that Andy Smiley Happy
  • 6.8K
  • 238
  • 1.4K
Message 6 of 11 (355 Views)
[ Edited ]
You can't just plug a wireless USB or wired ethernet adapter into any HDTV. It needs to be an Internet-Ready TV.
What is an Internet-Ready TV:
http://www.amazon.com/gp/feature.html?ie=UTF8&docId=1000535931
You can forget about this option if the TV is not an Internet-ready HDTV. You'd need an extra box to provide internet access that you then plug into your HDMI port. There are many available like Roku or Apple TV:
https://www.youtube.com/watch?v=mBgck_QrOK4
https://www.youtube.com/watch?v=nclLddytQrQ
Even if it was Internet-Ready or you use a box like the Roku that still wouldn't get the laptop display onto the TV screen. He could upload the pictures to a site or a flash drive, browse web sites and pictures from the TV and stream movies from Netflix but where is his laptop screen on the web? This isn't exactly what the OP asked for.
  • 6.8K
  • 238
  • 1.4K
Message 7 of 11 (345 Views)
[ Edited ]
How to do wireless display from your laptop:
1. WiDi
If your laptop has Intel WiDi built-in:
https://www.youtube.com/watch?v=mnP0d0UbLGo
NetGear Push2TV.
https://www.youtube.com/watch?v=3psUWOV1Xug
2. WiFi Direct
http://www.youtube.com/watch?v=4_QrYSEN2Vo
3. Wireless USB
Veebeam
https://www.youtube.com/watch?v=9yt4LmFYFFU
4. Wireless HD Kit. HDMI transmitter/receiver.
Usually quite expensive, more professional end of the market. See amazon.
How to connect your laptop to your TV:
http://www.pcmag.com/article2/0,2817,2390463,00.asp
http://gigaom.com/2011/03/08/imation-link-netgear-push2tv-veebeam-compared/
  • 6.8K
  • 238
  • 1.4K
Message 8 of 11 (342 Views)
[ Edited ]
Look on your Tv and Laptop to see if it has badges like DLNA, WiDi, WiFi Direct, Internet-Ready etc.
What model is your TV and what model is your computer? That might help.
  • 6.8K
  • 238
  • 1.4K
Message 9 of 11 (337 Views)
[ Edited ]
Using Samsung Galaxy SIII and NetGear Push2TV (Miracast) for displaying photos on HDTV:
https://www.youtube.com/watch?v=o7gMF2HNtn0
More about Miracast (which is built on WiFi Direct):
https://www.youtube.com/watch?v=cYagdOp9y7E
https://www.youtube.com/watch?v=6F_wyyZg5sI
http://www.wi-fi.org/wi-fi-certified-miracast%E2%84%A2
Message 10 of 11 (252 Views)
This is my TV
http://www.amazon.co.uk/Toshiba-42RV635DB-42-inch-Widescreen-Freeview/dp/B001TUYQ5K#productDescripti...
Doesnt say anything about internet ready... as for the computer are you asking what operating system... its Windows 7 64 bit
Even if I cant get my destop on my tv could I access my forders ?
Thanks everyone for your replies & help Smiley Happy
