  • 20
Message 1 of 8 (1,700 Views)
Wifi connection is disconnected every minute
Wifi connection is disconnected every minute.
Everything was fine before today. Any help would be appreciated.
Just joined
Message 2 of 8 (1,699 Views)
Re: Wifi connection is disconnected every minute
this will be due to black spots or interference, try changing your wireless channel in your routers configuration page.
Recommended WIFI channel;
1
6 or 11
hope this helps.
Danny
  • 20
Message 3 of 8 (1,695 Views)
I noticed these logs
[DHCP IP: (192.168.1.2)] to MAC address 00:15:AF:51:11:65, Monday, May 03,2010 23:05:23
[Admin login] from source 192.168.1.2, Monday, May 03,2010 23:04:47
[DOS attack: Teardrop] attack packets in last 20 sec from ip [89.117.241.219], Monday, May 03,2010 23:01:57
[DOS attack: Teardrop] attack packets in last 20 sec from ip [89.117.241.219], Monday, May 03,2010 23:01:36
[DOS attack: Teardrop] attack packets in last 20 sec from ip [89.117.241.219], Monday, May 03,2010 23:01:14
[DHCP IP: (192.168.1.3)] to MAC address 00:16:44:BF:E6:A1, Monday, May 03,2010 23:00:39
[DHCP IP: (192.168.1.2)] to MAC address 00:15:AF:51:11:65, Monday, May 03,2010 23:00:24
[DOS attack: ACK Scan] attack packets in last 20 sec from ip [212.159.7.178], Monday, May 03,2010 23:00:01
[DOS attack: Teardrop] attack packets in last 20 sec from ip [89.117.241.219], Monday, May 03,2010 22:58:48
[Time synchronized with NTP server] Monday, May 03,2010 22:58:33
[DOS attack: Teardrop] attack packets in last 20 sec from ip [89.117.241.219], Monday, May 03,2010 22:58:24
[DHCP IP: (192.168.1.2)] to MAC address 00:15:AF:51:11:65, Monday, May 03,2010 22:58:10
[DHCP IP: (192.168.1.3)] to MAC address 00:16:44:BF:E6:A1, Monday, May 03,2010 22:58:01
[Internet connected] IP address: 82.10.185.133, Monday, May 03,2010 22:57:23
[Internet disconnected] Monday, May 03,2010 22:57:22
[Initialized, firmware version: V1.0.11_1.0.1VGUK] Monday, May 03,2010 22:57:22
What shall I do with this? Why Dos attacks??
  • 20
Message 4 of 8 (1,692 Views)
and more
[DOS attack: Teardrop] attack packets in last 20 sec from ip [88.113.117.141], Monday, May 03,2010 23:15:02
[DOS attack: Teardrop] attack packets in last 20 sec from ip [89.117.241.219], Monday, May 03,2010 23:14:09
[DOS attack: Teardrop] attack packets in last 20 sec from ip [89.117.241.219], Monday, May 03,2010 23:13:45
[DOS attack: Teardrop] attack packets in last 20 sec from ip [89.117.241.219], Monday, May 03,2010 23:12:22
[DOS attack: Teardrop] attack packets in last 20 sec from ip [89.117.241.219], Monday, May 03,2010 23:11:52
[DOS attack: Teardrop] attack packets in last 20 sec from ip [89.241.18.239], Monday, May 03,2010 23:11:19
[DOS attack: Teardrop] attack packets in last 20 sec from ip [89.241.18.239], Monday, May 03,2010 23:10:49
  • 17.89K
  • 394
  • 3.14K
Message 5 of 8 (1,662 Views)
If you Google this:  how to deal with DoS attacks teardrop  there's advice on dealing with this.
Seph - (My advice is at your risk)
  • 20
Message 6 of 8 (1,635 Views)
URGENT SECURITY ISSUE: Re: Wifi connection is disconnected every minute
Why I do not see any reply from VM staff!
this is a security issue! And it is serious - you are allowing DOS attacks to reach my router.
Please, have a look and response what shall I do ?
Could you hide my IP-address at all and prevent this from happening? I did necessary changes to the router and got rid of those messages. But I still see something like this:
[Service blocked: ICMP_echo_req] from source 212.18.191.4, Tuesday, May 04,2010 18:05:15
[Service blocked: ICMP_echo_req] from source 78.62.210.142, Tuesday, May 04,2010 14:42:51
[Service blocked: ICMP_echo_req] from source 61.175.245.206, Tuesday, May 04,2010 13:28:26
[Service blocked: ICMP_echo_req] from source 118.37.243.170, Tuesday, May 04,2010 12:44:40
[Service blocked: ICMP_echo_req] from source 201.250.61.43, Tuesday, May 04,2010 12:41:09
[Service blocked: ICMP_echo_req] from source 202.69.187.106, Tuesday, May 04,2010 12:26:42
[Service blocked: ICMP_echo_req] from source 78.62.210.142, Tuesday, May 04,2010 10:40:30
HOW TO DEAL WITH THIS?
thanks
  • 17.89K
  • 394
  • 3.14K
Message 7 of 8 (1,629 Views)
Re: URGENT SECURITY ISSUE: Re: Wifi connection is disconnected every minute
On my Draytek router I have an option in my Firewall Menus that offers the following:
DoS defense Setup
Enable DoS Defense
 Enable SYN flood defenseThreshold packets / sec
  Timeout sec
 Enable UDP flood defenseThreshold packets / sec
  Timeout sec
 Enable ICMP flood defenseThreshold packets / sec
  Timeout sec
 Enable Port Scan detectionThreshold packets / sec
 Block IP optionsBlock TCP flag scan
 Block LandBlock Tear Drop
 Block SmurfBlock Ping of Death
 Block trace routeBlock ICMP fragment
 Block SYN fragmentBlock Unknown Protocol
 Block Fraggle Attack
Does your router have anything as comprehensive?
I'm not sure what VM can do other than to protect their routers from DoS attacks in a similar manner.  The attack that is hitting your router is not denying service at the VM UBR.
  • 4.94K
  • 100
  • 204
Message 8 of 8 (1,610 Views)
Hi Dimpers,
We're sorry for the delay in responding to your post.
Unfortunately if you are the target of a DOS attack there is little that we're able to do to prevent this.
We would recommend that you file a report with our Internet Security team at the following link:
http://netreport.virginmedia.com/netreport/index.php
Regards,
Peter Rafferty
Help and Support Forum Team
If someone's helped you out say thanks by clicking on the Kudos Star. If someone's solved your problem, why not mark their message as an Accepted Solution? You can also help other users find useful posts by Tagging them with keywords.
If you are new to the forum, please remember to search the forum before posting your question.
