Ess
Dialled in
  • 147
Message 1 of 10 (316 Views)
Superhub settings problem
is it me or has the default password and username for the superhub setting page changed? because i did  not change the p+u and now i am unable to go into the superhub settings? why is this?
  • 12.84K
  • 394
  • 1.6K
Message 8 of 10 (263 Views)
confirmed by Ess
Re: Superhub settings problem
hi again ess,
nothing like that is stored on the router it doesnt have the memory and ability to store such important information, i advise only advanced people who know what they are doing to go into the settings, or normal everyday users for stuff that they know about
thanks again
The artist formally known as Swt4ajp
4 the love of films >> Forum Guidelines
  • 12.84K
  • 394
  • 1.6K
Message 10 of 10 (234 Views)
confirmed by Ess
hi glad everything worked out for you
thanks
All Replies
  • 6.04K
  • 404
  • 1.08K
Message 2 of 10 (301 Views)
Shouldn't have, if you didn't change the password maybe someone has hacked into the hub and changed the password. You can do a pinhole reset to restore the default password and when you log into the hub change it.
Ess
Dialled in
  • 147
Message 3 of 10 (291 Views)
i did do restart (with the pin hole)
i think ill have to contact virgin asap.
  • 6.04K
  • 404
  • 1.08K
Message 4 of 10 (286 Views)
Odd did you hold the pin down for over 10 secs.
Have you powered off hub and repowered after 60 sec.
Corrupted firmware? otherwise.
Ess
Dialled in
  • 147
Message 5 of 10 (284 Views)
does that mean ill be needing a new superhub? because my internet seems to be perfect. ill have to wait and turn of the superhub tomorrow if not work then ring them.
  • 6.04K
  • 404
  • 1.08K
Message 6 of 10 (280 Views)
If everything is perfect I wouldn't want a new hub.
VM will probably be able to sort it by upgrading firmware from their end.
Ess
Dialled in
  • 147
Message 7 of 10 (276 Views)
yeah. is there anything to worry about being unable to access the superhub setting pages? meaning private and confidential information wise(passwords/credit card details) ?
  • 12.84K
  • 394
  • 1.6K
Message 8 of 10 (264 Views)
confirmed by Ess
hi again ess,
thanks again
Ess
Dialled in
  • 147
Message 9 of 10 (246 Views)
thats good.
thanks for the help
i reset it in the morning and i waited .. and it worked now changed the default password immediately thanks.
  • 12.84K
  • 394
  • 1.6K
Message 10 of 10 (235 Views)
confirmed by Ess
thanks
