  • 16
Message 1 of 5 (245 Views)
Superhub Speed
Just had a replacement superhub  and still can not get a stable connection at 300mbs,just drops the connection all the time. Thats 2 modems now with the same issues.I Know now virgin are recommending using the 145mbs setting..What actual contstant download speed is this capable of.Looks like I will have to revert to modem mode and use my trusty old  belkin router that never drops a 300mbs connection.You would think virgin would of  invested in decent equipment to start with knowing how many customers that will be using it.
All Replies
  • 12.84K
  • 394
  • 1.6K
Message 2 of 5 (243 Views)
Re: Superhub Speed
it is recommended to drop the speed to 145mb
or you use your own router
The artist formally known as Swt4ajp
4 the love of films >> Forum Guidelines
  • 99
  • 6
Message 3 of 5 (228 Views)
Re: Superhub Speed
i just put mine in modem mode and use a cheap router which is ton's better than vm superhub http://www.ebuyer.com/169923-tenda-wireless-n150-access-point-router-extender-w311r- £12 i have 4 wired and upto 10 wireless devices connected
  • 12.84K
  • 394
  • 1.6K
Message 4 of 5 (216 Views)
Re: Superhub Speed
looks cheap but cheerful looks like it would def do a better job lol Smiley Tongue
the only downfall of that router is the lan thoughput not being gigabit bit not everyone would need it
  • 114
  • 5
Message 5 of 5 (197 Views)
Re: Superhub Speed
Hi jcb208,
I am sorry to hear about the wireless issues. Other than changing channels I would suggest using the superhub in modem only mode and connecting your own router, as previously suggested by other posters.
Kev C
Help & Support Forum Team
If someone's helped you out say thanks by clicking on the Kudos Star. If someone's solved your problem, why not mark their message as a Helpful Answer? You can also help other users find useful posts by Tagging them with keywords.Got a problem? Check for faults online with our service status and fault checker.
If you are new to the forum, please remember to search the forum before posting your question. Please don't send private messages directly to the forum team unless they ask you to, post your issue to the forum first.
