  • 8
Message 1 of 5 (11,547 Views)
Sony Xperia phone won't connect to WiFi Superhub
My wife has just bought herself a Sony Xperia Miro phone.
When we try to get a WiFi connection it finds the superhub no problem, tells us the signal strength is excellent and that it is secured with WPA/WPA2 PSK
enter the password and try to connect and it comes back saying "Authentication problem"
It connects no problem in the local cafe which offers free wifi and also uses WPA/WPA2 security.
I have an Ipad and laptops running Windows and Linux connecting with no problem so I'm sure I've got the password correct.
Any suggestions?
Dialled in
  • 82
Message 3 of 5 (11,535 Views)
confirmed by RBurns1
‎28-08-2015 00:15
Re: Sony Xperia phone won't connect to WiFi Superhub
I have the Sony Xperia Miro, and connection to the Super Hub works .... eventually Smiley Frustrated
There is a known problem sometimes connecting the Super Hub with Android phones, but appears the fault is with the Super Hub itself. Currently awaiting a fix.
All Replies
Rising star
  • 788
  • 29
  • 85
Message 2 of 5 (11,498 Views)
The default password key on the superhub should be AES not TKIP, i would login to the superhub and double check its set to AES, if so it maybe the phone is detecting it wrong for some strange reason.
The only thing i can think to do is to change it to TKIP from AES and then to rejoin all the other devices if it works.
Dialled in
  • 82
Message 3 of 5 (11,536 Views)
‎28-08-2015 00:15
  • 9.9K
  • 264
  • 966
Message 4 of 5 (11,326 Views)
Hi RBurns1,
In addition to the helpful suggestions already provided, please reboot the hub. In all honesty I tested this issue myself and a reboot allowed my android to connect.
If that doesn't help, please try a factory reset of the hub.
Jen
  • 6
Message 5 of 5 (11,264 Views)
I was baffled at first with similar problem on Sony Tipo phone. At the moment it works by pressing the sync button on the SH for about 2 secs until it flashes red & blue, then the phone connects (this is WPS sync, but I don't understand because there is no WPS on the phone!)
