Message 1 of 4 (90 Views)
Problems with disconnection and power levels!!!
I hope I will find help here.
First of all sorry for my language.
I have got a problems for long time now. We sharing our 50m connection with my brother. In total we have got 4 devices connected to the super hub. 2 ethernet connection and 2 wirelles.
Unfortunately we have got frequent disconnections, internet is very slow or sometimes there is no connection for a few minutes. Also sometimes we can not connect wiressly with the router and only reset of hub is helping.
I checked a power level:
Startup Procedure
ProcedureStatusComment
Acquire Downstream Channel298750000 HzLocked
Connectivity StateOKOperational
Boot StateOKOperational
Configuration FileOK
SecurityEnabledBPI+
Downstream Channels
Lock StatusModulationChannel IDMax Raw Bit RateFrequencyPowerSNRDocsis/EuroDocsis locked
LockedQAM2562655616000 Kbits/sec298750000 Hz11.9 dBmV41.4 dBHybrid
LockedQAM2562555616000 Kbits/sec290750000 Hz12.4 dBmV41.4 dBHybrid
LockedQAM2562955616000 Kbits/sec306750000 Hz12.3 dBmV41.4 dBHybrid
LockedQAM2563055616000 Kbits/sec314750000 Hz11.5 dBmV40.9 dBHybrid
UnlockedUnknown00 Ksym/sec0 Hz0.0 dBmV0.0 dBUnknown
Upstream Channels
LockedATDMA220480 Kbits/sec35800000 Hz43.0 dBmV
Downstream(0)
SFID666
Max Traffic Rate53000000 bps
Max Traffic Burst3044 bytes
Mix Traffic Rate0 bps
Primary Upstream Service Flow
Upstream(0)
SFID665
Max Traffic Rate5140000 bps
Max Traffic Burst8160 bytes
Max Concatenated Burst8160 bytes
Scheduling TypeBest Effort
I phoned a virgin a few times, someone also came and change a super hub for the new one and they have installed a new cable from steeet box to our house, but this didn't sort our problems.
I lost completely a power to fight for a better service!
I'm hoping somebody can help me on here. Can anyone check my power levels?
And maybe let me know what the problem can be with a dificultiess to connect wirellessly.
For all help and advice huge thanks!
Eazeo83
London, superhub
All Replies
  • 19.28K
  • 584
  • 2.48K
Message 2 of 4 (86 Views)
Re: Problems with disconnection and power levels!!!
your downstream power is to high and could do with being lowered by a local engineer.
2 ways to get this done
1) Wait for a forum admin to reply (3 to 5 days normally) and they can book you a engineer.
2) Call VM on 151 from your VM line and inform them of the power levels and they should book you a Engineer.
If you book a Engineer over the phone please post here to let us know so a VM tech dosn't waste time sorting this for you.
Sadly not a Virgin customer anymore.... Unless you want to cable my new street. my internet sucks.
Message 3 of 4 (58 Views)
Hello again.
I phone VM today and they have booked a engineer for Monday afternoon. Will keep finger cross that they can sort this out for me.
Thank you very much for a advice.
Will update you on Monday.
  • 3.33K
  • 38
  • 130
Message 4 of 4 (50 Views)
Hi eazeo83
Was the engineer able to resolve this problem?
Regards,
Chris Kean
Help & Support Forum Team
If someone's helped you out say thanks by clicking on the Kudos Star. If someone's solved your problem, why not mark their message as an Accepted Solution? You can also help other users find useful posts by Tagging them with keywords.
If you are new to the forum, please remember to search the forum before posting your question.
