  • 10
Message 1 of 7 (1,652 Views)
Only 0.5 mbps upload speed on 10 mbps connection
Hello There,
I have recently had my services installed which overall I am very happy with.  However my upload speed seems to be consistently slower than my old ADSL.  On speedtest.net I always get 0.55 mbps no matter what the time of day.  I was expecting this to be about 1mbps.  Just wondering if anyone has any clues as to why this is a bit slow.
I'm including my tracert results and my hub settings.  As this is an upload query I have not included my download test results.
HUB  (This seems to be set to 512000 bps)
Primary Upstream Service FlowUpstream(0)SFID8421Max Traffic Rate512000 bpsMax Traffic Burst1600 bytesMix Traffic Rate0 bpsMax Concatenated Burst1522 bytesScheduling TypeBest Effort
TRACERT
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Dug>tracert bbc.co.uk
Tracing route to bbc.co.uk [212.58.224.138]
over a maximum of 30 hops:
  1    12 ms     7 ms     7 ms  10.9.128.1
  2     7 ms     8 ms     7 ms  aztw-geam-1b-v15.network.virginmedia.net [80.192
.0.3]
  3     7 ms     9 ms     7 ms  aztw-core-1b-ae0-0.network.virginmedia.net [80.1
.241.13]
  4    14 ms    20 ms    10 ms  brhm-bb-1b-as1-0.network.virginmedia.net [213.10
5.175.161]
  5    12 ms    13 ms    11 ms  nrth-bb-1a-as4-0.network.virginmedia.net [62.253
.185.105]
  6    11 ms    13 ms    11 ms  nrth-bb-1b-ae0-0.network.virginmedia.net [62.253
.185.118]
  7    56 ms    21 ms    11 ms  nrth-tmr-2-ae6-0.network.virginmedia.net [213.10
5.159.34]
  8    16 ms    16 ms    16 ms  tele-ic-1-as0-0.network.virginmedia.net [62.253.
184.2]
  9    15 ms    14 ms    14 ms  pos6-1.rt0.thdo.bbc.co.uk [212.58.239.237]
 10    14 ms    13 ms    13 ms  212.58.238.153
 11    13 ms    13 ms    13 ms  virtual-vip.thdo.bbc.co.uk [212.58.224.138]
Trace complete.
Microsoft Windows XP [Version 5.1.2600](C) Copyright 1985-2001 Microsoft Corp.
Tracing route to bbc.co.uk [212.58.224.138]over a maximum of 30 hops:
  1    12 ms     7 ms     7 ms  10.9.128.1  2     7 ms     8 ms     7 ms  aztw-geam-1b-v15.network.virginmedia.net [80.192.0.3]  3     7 ms     9 ms     7 ms  aztw-core-1b-ae0-0.network.virginmedia.net [80.1.241.13]  4    14 ms    20 ms    10 ms  brhm-bb-1b-as1-0.network.virginmedia.net [213.105.175.161]  5    12 ms    13 ms    11 ms  nrth-bb-1a-as4-0.network.virginmedia.net [62.253.185.105]  6    11 ms    13 ms    11 ms  nrth-bb-1b-ae0-0.network.virginmedia.net [62.253.185.118]  7    56 ms    21 ms    11 ms  nrth-tmr-2-ae6-0.network.virginmedia.net [213.105.159.34]  8    16 ms    16 ms    16 ms  tele-ic-1-as0-0.network.virginmedia.net [62.253.184.2]  9    15 ms    14 ms    14 ms  pos6-1.rt0.thdo.bbc.co.uk [212.58.239.237] 10    14 ms    13 ms    13 ms  212.58.238.153 11    13 ms    13 ms    13 ms  virtual-vip.thdo.bbc.co.uk [212.58.224.138]
Trace complete.
any advice welcome
  • 19.28K
  • 584
  • 2.48K
Message 5 of 7 (1,621 Views)
confirmed by DugS
Re: Only 0.5 mbps upload speed on 10 mbps connection
if your upstream stable to 54 or dies it go up over 55?
refresh the page every few seconds to see if its changing much.
if its stable then all looks good
Sadly not a Virgin customer anymore.... Unless you want to cable my new street. my internet sucks.
All Replies
  • 19.28K
  • 584
  • 2.48K
Message 2 of 7 (1,642 Views)
you seem to not be in a upgraded area. only upgraded area will have the faster upload rate.
its just awaiting game
  • 6.04K
  • 404
  • 1.08K
Message 3 of 7 (1,639 Views)
   VM are currently upgrading upload speeds, you can check if your area has been upgraded. When I was on 20mb package the advertised (pre Upgrade)  upload speed was 750kb/s (never got close) so 055mb/s sounds about right. You can check your area Here.
  Could you post your modem power levels and modulation so they can be checked as per Mark's sticky at the top of the forum.
  • 10
Message 4 of 7 (1,634 Views)
Ah yes, thanks guys I have just found the upgrade schedule.  Sorry I hadn't already got this far.  To be fair I'm not too unhappy with 0.5mbps as long as it gets upgraded in the future some time.
Here are all my hub settings as requested :
Startup Procedure
ProcedureStatusComment
Acquire Downstream Channel339000000 HzLocked
Connectivity StateOKOperational
Boot StateOKOperational
Configuration FileOK
SecurityEnabledBPI+
Downstream Channel
Lock StatusLockedModulationQAM256
Channel ID7Symbol Rate5360537
Downstream Frequency339000000 HzDownstream Power0.0 dBmV
SNR33.0 dBmV
Upstream Channel
Lock StatusLockedModulationQAM16
Channel ID2Symbol Rate2560 Ksym/sec
Upstream Frequency22200000 HzUpstream Power54.0 dBmV
Downstream(0)
SFID8422
Max Traffic Rate10240000 bps
Max Traffic Burst3044 bytes
Upstream(0)
SFID8421
  • 19.28K
  • 584
  • 2.48K
Message 5 of 7 (1,622 Views)
confirmed by DugS
  • 10
Message 6 of 7 (1,601 Views)
Yep all stable at 54 - thanks guys.  And to be honest the connection is a lot more stable and faster for PS3 gaming than my old adsl was with higher upload speeds.
thanks
  • 3.89K
  • 75
  • 222
Message 7 of 7 (1,444 Views)
Hi DugS,
Thanks for letting us know your issue is now resolved.
Regards,
James Gilbert
Help & Support Forum Team
If someone's helped you out say thanks by clicking on the Kudos Star. If someone's solved your problem, why not mark their message as an Accepted Solution? You can also help other users find useful posts by Tagging them with keywords.
If you are new to the forum, please remember to search the forum before posting your question.
Please can we ask you not to PM the Forum team unless requested to do so by us
