Message 1 of 7 (842 Views)
Netgear wireless n cable gateway VMDG280
Ive had this VM wireless for several months now and I'm having nothing but trouble,
My internet always disconnects I have to reset the router 3times a day, it runs as slow as anything
My mobile connection is just as slow
Please sort this out otherwise I'll be leaving
Hero
  • 6.84K
  • 252
  • 671
Message 2 of 7 (840 Views)
Re: Netgear wireless n cable gateway VMDG280
What have you tried to sort it out so far?
  • 135
Message 3 of 7 (837 Views)
see here the post by ceptic, its improved mines reliability but the range is still rubbish
http://community.virginmedia.com/t5/Wireless/Intermittant-wireless-on-all-wireless-devices-ethernet-...
id advise using a free app such as wifi analyser to see what other wifi is operating near you so you can pick the most suitable channel, on one of the channels on mine i get connection ok but no actual internet whatsoever
Message 4 of 7 (835 Views)
I've been told to disconnect it over night the next day it'll b fine it's ok for 10mins then dead again just waiting for this page to refresh has taken 5mins
What else can I try?
  • 7.54K
  • 449
  • 1.3K
Message 5 of 7 (823 Views)
[ Edited ]
you could try ringing retentions - 150 from VM phone option 5 option 2 - they are the i want to leave dept - they also do many other thinks
tell them you want a super hub but at no cost to you - if you are pleasant with them most things are possible - it may or may not improve what you have today wifi wise - but it gives the the option of modem mode which means you can add your own router and that will ceratinly solve all your problems assuming your connection is good and you dont have high utilisation in your area
____________________
Tony
Message 6 of 7 (812 Views)
What else can I do?
  • 1.08K
  • 15
  • 52
Message 7 of 7 (781 Views)
Hi Stevieb85,
I have sent you a Private Message. We'll be happy to progress things for you once we have received your reply.
Darren_G
Help & Support Forum Team
