Message 1 of 5 (4,775 Views)
Netgear Router Problem
Hi all
Like many others I'm having real problems with wireless constantly dropping out - I have to reset it it several times a day now and in the last few weeks it's been the worst ever.  I have the Virgin National service and my line is with BT (who have checked the line and been really helpful I would add). On phoning Virgin I was more or less told I shouldn't reset it when it goes down and that I should phone them when it happens. No matter how much I explained the different things I have tried I didn't get anywhere.
I asked about a new router and was told they would not supply it because I have had the original one they supplied for 2 and a half years and it is out of warranty! I was a bit taken aback at this because I presumed as it was Virgin's equipment that they would supply a replacement if it was faulty.
Anyway, my question is, can I just go out and buy any wireless router?  Is it actually a modem/router I need? How would I be able to connect this to Virgin Broadband if I do?  Honestly I think this would be cheaper than constant calls to Virgin
Any help would be very much appreciated.
  • 12.34K
  • 855
  • 2.09K
Message 2 of 5 (4,788 Views)
confirmed by aakcat
‎28-08-2015 00:15
Re: Netgear Router Problem
yes you can use any ADSL router, best to get a ADSL2 dual band Modem router, so its all combined into 1.. what router do you have currently, eg make/model? also depends on your budget aswell..
ADSL settings for the UK
If you need to check or amend the settings used by your ADSL equipment, this is the information you need to know:
VPI
0
VCI
38
Encapsulation mode
PPP over ATM (PPPoA) VC-MUX
Authentication type
CHAP
Recommended MTU
1458
If someone's helped you out say thanks by clicking on the Kudos Star. If someone's solved your problem, why not mark their message as an Accepted Solution
  • 12.34K
  • 855
  • 2.09K
Message 4 of 5 (4,737 Views)
confirmed by aakcat
‎28-08-2015 00:15
you could try and update the firmware on the router - http://support.netgear.com/app/answers/detail/a_id/12760
you could take a look at- http://www.broadbandbuyer.co.uk/default_ShopGroup.asp?ShopGroupID=38
All Replies
  • 12.34K
  • 855
  • 2.09K
Message 2 of 5 (4,789 Views)
confirmed by aakcat
‎28-08-2015 00:15
VPI
0
VCI
38
Encapsulation mode
Authentication type
CHAP
Recommended MTU
1458
Message 3 of 5 (4,744 Views)
Thanks for your reply Woman Very Happy
I have a Netgear ADSL2+ Modem-Router and the model number is DG834g v5.   Budget is fully flexible really and I'm quite happy to go for quality and pay the price. Any suggestions gratefully received.
Cheers again.
  • 12.34K
  • 855
  • 2.09K
Message 4 of 5 (4,738 Views)
confirmed by aakcat
‎28-08-2015 00:15
Message 5 of 5 (4,688 Views)
Cheers for that - I'll try that tonight and source a new router if it doesn't get better Robot Very Happy
