  • 5
Message 1 of 9 (164 Views)
My Upload Speed
My upload speed is 1.00mbps - 1.99mbps you can even run a server on that i was hoping i can get it to be 10.00mpbs for free so i can run a server because at the moment i can only run a 6 player server i want a 30 player server if i get 10.00mbps that will be realy good but if you can can you make it about 15.00mbps - 25.00mbps if not just have it as 10.00mbps. Thats if you can
Thanks,Connor
  • 14.64K
  • 1.16K
  • 2.03K
Message 2 of 9 (163 Views)
Re: My Upload Speed
Your upload speed depends on your download speed.
The current fastest available upload speed you can get is 5Mbit with XXL 100Mbit (although eventually XXL will be upgraded to 120Mbit down with a 12Mbit upload)
  • 5
Message 3 of 9 (161 Views)
Re: My Upload Speed
My Download speed is 30mbps am i ment to get 1.00mbps - 1.99 mbps then and if so is there any way i can get it higher.
  • 14.64K
  • 1.16K
  • 2.03K
Message 4 of 9 (158 Views)
Re: My Upload Speed
Depends which 30Mbit package you are on. The current L 30 does have a 2Mbit upload, an older XL30 package which is no longer available has a 3Mbit upload.
As I said, the only way to increase your upload is to upgrade to a higher download package.
  • 5
Message 5 of 9 (156 Views)
Re: My Upload Speed
So if i got the 100mbps internet from vergin ill have higher upload speed
  • 14.64K
  • 1.16K
  • 2.03K
Message 6 of 9 (154 Views)
Re: My Upload Speed
Yes
  • 5
Message 7 of 9 (152 Views)
Re: My Upload Speed
How much more will it cost?
  • 14.64K
  • 1.16K
  • 2.03K
Message 8 of 9 (149 Views)
Re: My Upload Speed
That would be question for Customer Services
  • 5
Message 9 of 9 (147 Views)
Re: My Upload Speed
Okay thanks for the help
