  • 29
Message 1 of 8 (17,014 Views)
Manual for Superhub
[ Edited ]
I recently received the new Virgin Netgear Superhub. The installation guide does not enlighten the user about the significance of the various lights on the front of the hub.
I was told by tech support that the middle green light must be stable for Internet access to be established. And when access to the web was established the top green light turned bright blue.
Is there a manual that can be downloaded that explains what each light actually signifies?
And why does the top blue light and the bottom green light flash occassinally even when my PC is switched off?
  • 14.64K
  • 1.16K
  • 2.03K
Message 2 of 8 (17,041 Views)
confirmed by drcce2001
‎28-08-2015 00:15
Re: Manual for Superhub
This should help Smiley Wink
What do the lights on the Virgin Media Super Hub mean?
All Replies
  • 14.64K
  • 1.16K
  • 2.03K
Message 2 of 8 (17,042 Views)
‎28-08-2015 00:15
  • 29
Message 3 of 8 (17,001 Views)
thanks very much for the link.
  • 29
Message 4 of 8 (16,994 Views)
[ Edited ]
I have an ethernet connection from PC to the hub. The ethernet light on the hub is amber indicating a connection speed of 100 Mbps. I am on the Virgin 30 Mbps broadband service. Is amber the expected colour for this?
Why does the blue Traffic light flash occasionally even when my PC is switched off?
  • 14.64K
  • 1.16K
  • 2.03K
Message 5 of 8 (16,980 Views)
You would need a Gigabit ethernet card in your PC for the light on the ethernet port to be Green.
The reason the lights blink occasionally is just routine 'is anything there' type traffic.
  • 29
Message 6 of 8 (16,878 Views)
But a gigabit ethernet card is surely not necessary for a 30 Mbps service? Or is there some advantage that I am not aware of to having such a card for a 30Mbps broadband conenction?
Isn't a 1000 Mbps option merely future proofing the Superhub for a time when a 1000 Mbps broadband service vecomes availabele?
  • 31
  • 12
Message 7 of 8 (16,847 Views)
___________________________________________________________________________________
Hope this helps clear it up a bit for you.
http://ask-leo.com/why_didnt_my_gigabit_network_card_result_in_better_performance.html
So in other words dont worry about making that amber light turn green to the point you will freak out ang buy a new Gigabit network card for your PC Smiley Happy. It will not improve your actual connection to the internet. That is taken care of solely by the modem inside you router.
Message 8 of 8 (7,964 Views)
hey thnx Smiley Wink i now have 3 lights working which iz cool & thnx for a uncomplcated answer & now i can stop thinking abot the lightz lolz Smiley Happy
