Message 1 of 9 (1,761 Views)
Known Broadband Problems in my area
Please could you take a look at the broadband connectivity in my area. Fault Reference: F001959848
Superfast
  • 188
  • 19
  • 79
Message 2 of 9 (1,677 Views)
Re: Known Broadband Problems in my area
The card went offline and a soft reset of the card restored service.
bmly-cmts-08.network.virginmedia.net : LinkDown on Interface: Modular-Cable7/0/0:13 Reason: down enterprise
its a priority 1 and there working on it im not aloud to present any more information other than that.
if i help, please give kudos
it takes 2 second to click the star on the right
I work for Virgin - but all opinions posted here are my own
Message 3 of 9 (1,671 Views)
Thank you very much
Superfast
  • 188
  • 19
  • 79
Message 4 of 9 (1,557 Views)
no problem Smiley Happy
Message 5 of 9 (1,549 Views)
The Internet on the tv is working fine. Could there be an issue with my router?
Message 6 of 9 (1,542 Views)
Also a friend who lives close has no problem with their virgin media broadband
  • 3.54K
  • 17
  • 172
Message 7 of 9 (1,503 Views)
Hi Ben_alcock,
I have sent you a Private Message. We'll be happy to progress things for you once we have received your reply.
I work for Virgin Media but my opinions are my Own
Message 8 of 9 (1,446 Views)
My broadband keeps dropping off or is very slow and has been for the last 4 days. I can't even download an issues of the times ipad edition. I've rebooted the router etc numerous occasions and have several wired and wireless devices. I think its a wide area problem not the LAN. Could you look into it please. Postcode W4. Happy to provide account number. There is a 30 min+ wait for phone support.
Thanks Paul
  • 2.8K
  • 21
  • 159
Message 9 of 9 (1,418 Views)
Hi paulbakstad,
I've run various checks on your modem and the network in your area but am unable to see anything that looks out of place. Is it possible to connect just one of your computers directly to the modem, with the wireless switched off please? If you are using a superhub then can you try putting this into Modem Mode? Do you still have the same connection problems when this has been done?
If not, the wireless settings are likely to be the cause. If you do continue to have the same issues though, that would suggest a fault that I am currently unable to detect and I would ask if you could post a traceroute and ping test to both bbc.co.uk and to The Times website please?
Kind Regards,
Jason G.
Help & Support Forum Team
