  • 39
Message 1 of 4 (2,389 Views)
How can I improve my wireless connection signal?
I've just got a new NETGEAR Wireless-N 300 router, and I used the 'set-up wizard' software to get it up and running. The router is situated in the same room as my laptop, and only a few feet away, with no obstructions between the router and the laptop. But despite this, when I check the signal strength, my laptop says the signal strength is 'poor'.
What can I do to get the strength up to 'excellent'?.
Thanks.
Trouble shooter
  • 2.81K
  • 140
  • 666
Message 2 of 4 (2,381 Views)
Re: How can I improve my wireless connection signal?
There is a similiar thread here http://community.virginmedia.com/t5/Wireless/Poor-Wireless-Speeds/m-p/70938#M2643 which may give you some ideas.
  • 39
Message 3 of 4 (2,379 Views)
OK, thanks.
I'll have a look.
  • 12.32K
  • 853
  • 2.08K
Message 4 of 4 (2,362 Views)
hiya jack
also just to add you can check - http://help.virginmedia.com/system/selfservice.controller?CONFIGURATION=1002&PARTITION_ID=1&TIMEZONE...
also - http://www.voip-sol.com/10-ways-to-boost-your-wifi-signal/
If someone's helped you out say thanks by clicking on the Kudos Star. If someone's solved your problem, why not mark their message as an Accepted Solution
