  • 5
Message 1 of 5 (204 Views)
High ping, low download speed
http://www.speedtest.net/result/1782072116.png
I think it's hmm, a little sub-optimal for what im paying to put it nicely
Startup Procedure
ProcedureStatusComment
Acquire Downstream Channel402750000 HzLocked
Connectivity StateOKOperational
Boot StateOKOperational
Configuration FileOK
SecurityEnabledBPI+
Downstream Channel
Lock StatusLockedModulationQAM256
Channel ID2Symbol Rate5360537
Downstream Frequency402750000 HzDownstream Power-3.3 dBmV
SNR39.9 dBmV
Upstream Channel
Lock StatusLockedModulationQPSK
Channel ID1Symbol Rate2560 Ksym/sec
Upstream Frequency22200000 HzUpstream Power37.0 dBmV
Downstream(0)
SFID304
Max Traffic Rate10240000 bps
Max Traffic Burst3044 bytes
Mix Traffic Rate0 bps
Primary Upstream Service Flow
Upstream(0)
SFID303
Max Traffic Rate1072000 bps
Max Traffic Burst8160 bytes
Max Concatenated Burst8160 bytes
Scheduling TypeBest Effort
All Replies
Fibre optic
  • 482
  • 18
  • 57
Message 2 of 5 (190 Views)
Re: High ping, low download speed
Are you sure you copy&pasted that modem connection info correctly?  I ask that because I can only see one downstream channel there, when typically the SH stats screen will show 8, 4 of which would be typically used and 4 unused.
If you really do only have one downstream channel then I'd see that as a problem.  I'd also suggest the power level on the downstream you do have should be higher, -3 to +7 is the rule of thumb optimal range, and you're at the very bottom end and arguably off it.
Assuming posted info is correct you'd likely need an engineer visit.  Fastest way to do that would be to call VM, slowest way would be to wait 7 days or so for a forum tech response.
cmbg15-2-0 Overutilised since at least January 2011.
http://community.virginmedia.com/t5/Fibre-optic-broadband-cable/Update-for-Cambridge-users-on-cmbg15-2-0/td-p/358435
Hero
  • 6.76K
  • 245
  • 662
Message 3 of 5 (188 Views)
[ Edited ]
The op is only on 10mb so only has 1 downstream. 3.3 is very close to optimal, id be shocked to see a tech sent to that
Fibre optic
  • 482
  • 18
  • 57
Message 4 of 5 (185 Views)
Good point, I hadn't check the provisioning and assumed that because this was in the 50Mb forum that it was a 50Mb user.
Dialled in
  • 334
  • 19
Message 5 of 5 (157 Views)
Hi Goode400,
Hi I have checked your network segment in regards to your slow speed issue. I have not found any issues on the network. We require for further tests to be carried out if you could view this Slow Speed FAQ and follow all checks please. Could you then post the results here and we will take a look for you.
Kind Regards,
David_Smale
Help & Support Forum Team
