Message 1 of 3 (1,113 Views)
Help to connect Ethernet printer to new super hub please
Printer is HP deskjet 6127
I have dell inspiron 9400 laptops running windows XP
I have just upgraded my broadband and the new virgin media super hub has been installed and all is working fine.......
However I previously had the above printer working wireless via Ethernet cable through my old router to both laptops
for the life of me I can not work out how to do it again for the super hub can you help
I have successfully printed off a network configuration page ....... What next ?
All Replies
Rising star
  • 938
  • 18
  • 107
Message 2 of 3 (1,108 Views)
Re: Help to connect Ethernet printer to new super hub please
Try the links below;
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=115&prodSeriesId=...
http://www.ehow.com/how_6675771_set-up-hp-deskjet-network.html
http://driverscollection.com/?file_cid=39934903470c0c1691bfdb40941
It might also be worth disabling the IP Flood Protection and Firewall in the SuperHub as this COULD block your printer from accessing your network- as long as you've got a decent firewall on your pc's it will be fine.
Hope this helps Smiley Happy
_______________________
I do not work for Virgin Media or any other TV, Broadband or Telephone company.
Virgin Media XL 20mb Broadband Latency
Message 3 of 3 (1,016 Views)
Thanks for trying to help but the links did not quite point in the right direction.....
in the end i deleted privious printer setings and uploaded the following driver with its product user guide when i ran the program it searched for network printers and found the printer strait away and althrough it did not print the trest page at the end of instolation it is now printing my pdf's fine
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=dj-7526-2&lc=en&dlc=en&cc=us&o...
why this could find the printer wirelessly conected to the hub where were as the windows add printer wizard could not i dont know ........
thanks for you help
aj
