  • 26
Message 1 of 6 (5,608 Views)
FTP Client Won't Connect - ECONNREFUSED
When attempting to connect to my FTP server using Filezilla I get the error: Connection attempt failed with "ECONNREFUSED - Connection refused by server".
I have run the network configuration wizard and it fails to receive a responce.
Connecting to probe.filezilla-project.org
Response: 220 FZ router and firewall tester ready
USER FileZilla
Response: 331 Give any password.
PASS 3.3.5.1
Response: 230 logged on.
Checking for correct external IP address
Retrieving external IP address from http://ip.filezilla-project.org/ip.php
IP 94.174.103.119 je-bhe-bad-bbj
Response: 200 OK
PREP 53239
Response: 200 Using port 53239, data token 1714236237
PORT 94,174,103,119,207,247
Connection timed out.
Connection closed
Connecting to probe.filezilla-project.orgResponse: 220 FZ router and firewall tester readyUSER FileZillaResponse: 331 Give any password.PASS 3.3.5.1Response: 230 logged on.Checking for correct external IP addressRetrieving external IP address from http://ip.filezilla-project.org/ip.phpChecking for correct external IP addressIP 94.174.103.119 je-bhe-bad-bbjResponse: 200 OKPREP 53239Response: 200 Using port 53239, data token 1714236237PORT 94,174,103,119,207,247Connection timed out.Connection closed
I have tried setting port forwarding for FTP ports and putting the computer in the DMZ, no luck.
However when I plug my computer into my still active BT connection it connects to my server no problem and the connection wizard test complete's successfully.
Am I missing something in the Super Hub Settings?
All Replies
  • 12.12K
  • 828
  • 2.02K
Message 2 of 6 (5,595 Views)
Re: FTP Client Won't Connect - ECONNREFUSED
if you go into the services features under content filtering and untick firewall features and IP flood detection, and apply and see what happens.
If someone's helped you out say thanks by clicking on the Kudos Star. If someone's solved your problem, why not mark their message as an Accepted Solution
  • 26
Message 3 of 6 (5,592 Views)
Already done, also disabled firewall features, has made no difference!
  • 19.28K
  • 584
  • 2.48K
Message 4 of 6 (5,572 Views)
looks like its logging you in but can't get yoru external ip. are you using another router connected to the superhub.
2 things to try.
In the site manager try...
1)  in the transfer settings try both active and passive mode.
2) in the options under connection -> FTP -> Active mode, select use the following ip address and set your ip manually.
check your ip at http://www.ip-adress.com/
Sadly not a Virgin customer anymore.... Unless you want to cable my new street. my internet sucks.
  • 26
Message 5 of 6 (5,560 Views)
[ Edited ]
Below it receives the correct IP, it is failing on receiving a responce.
Response: 200 OK
This is the test successfully finishing through the BT Line:
USER FileZilla
PASS 3.3.5.1
IP 217.42.193.16 cbh-ec-bjd-bg
Response: 200 OK
PREP 49650
Response: 200 Using port 49650, data token 1547567881
PORT 217,42,193,16,193,242
Connection closed
It seems the test is not receiving a responce from the server once and the connection is timing out.
VM Test:
USER FileZilla
PASS 3.3.5.1
Response: 200 OK
PREP 49999
Response: 200 Using port 49999, data token 1333639299
PORT 94,174,103,119,195,79
Connection closed
But now for some strange reason I am now able to connect to my web server without the ECONREFUSED error when connecting using the Virgin Media connection.
As seen above the test is still timing out so I am confused as to how/ what was going on.
Up to speed
  • 177
  • 5
  • 16
Message 6 of 6 (5,530 Views)
Perhaps the FileZilla forums can help you:
http://forum.filezilla-project.org/viewtopic.php?f=2&t=19674
