  • 9
Message 1 of 9 (1,240 Views)
Ethernet v WiFi - How much slower should wireless be?
When I connect my laptop to the Netgear router with an Ethernet cable and run the thinkbroadband speedtest I get 9.2 or 9.3 which is OK for up to 10Mb.  When I use WiFi, even with the laptop about 0.5metres from the Netgear router, I get a speed of 4.2.  I know WiFi is a bit slower than a cable but this much slower?
All Replies
  • 19.29K
  • 584
  • 2.48K
Message 2 of 9 (1,239 Views)
Re: Ethernet v WiFi - How much slower should wireless be?
it can depend on alot of factors. we get that much interferance at work in one of the buildings wifi dosn;t work at all.
you can try loggin into the rouer and changing the wireless channel
Sadly not a Virgin customer anymore.... Unless you want to cable my new street. my internet sucks.
  • 9
Message 3 of 9 (1,218 Views)
In a residential area so think there is not much interference from outside.
Also, speed does not seem to alter when our fridge cuts in or out.
Router channel is set to auto - am i naive expecting that to give best result?
  • 19.29K
  • 584
  • 2.48K
Message 4 of 9 (1,215 Views)
on the superhub auto has been known to pick bad channels. try 1 6 or 12
  • 9
Message 5 of 9 (1,211 Views)
Thanks.  I will try that later today.
  • 9
Message 6 of 9 (1,196 Views)
Scientific test results
The router is a VMDG280 located about 1.5m above floor
The laptop is just below the router - within 1 metre
There is a freezer nearby, but below the level of the router.  There is a radiator through the wall, also below the level of the router.
Using thinkbroadband speed test
15:17  Auto Channel    4.1 (Freezer on)
15:20  Auto Channel    4.0 (Freezer on)
15:23  Ethernet Cable  9.2
15:26  Auto Channel    4.1 (Freezer off)
15:29  Channel 1         4.0 (Freezer off)
15:35  Channel 6         4.2 (Freezer off)
15:38  Channel 12       4.0 (Freezer off)
15:41  Auto Channel    4.2 (Freezer off)
So, setting channel does not help any.
To return to the original question, is a Wireless speed which is 50% of the cable speed typical, normal - given the short range (1 metre) ?
  • 9
Message 7 of 9 (1,194 Views)
I meant to note that I can see 8 other networks round about, so I reckon my PC is OK
  • 5.09K
  • 97
  • 285
Message 8 of 9 (1,171 Views)
Hi glen_almond,
We're unable to guarantee any speed via wireless due to the numerous factors which have to be considered. Can you get hold of a 2nd laptop to test your wireless speeds? What is the make/modem of the wireless adapter inside your laptop and are the drivers up to date?
Regards,
Ray Miranda
Help & Support Forum Team
If someone's helped you out say thanks by clicking on the Kudos Star. If someone's solved your problem, why not mark their message as a Helpful Answer? You can also help other users find useful posts by Tagging them with keywords.
If you are new to the forum, please remember to search the forum before posting your question. Please don't send private messages directly to the forum team unless they ask you to, post your issue to the forum first.
Got a problem? Check for faults online with our new service status and fault checker
Problem sorter
  • 3.01K
  • 90
  • 315
Message 9 of 9 (1,161 Views)
What is your link rate? (speed wifi shows on connection).
If it's 45 meg (g) then I dont think your results are that odd.
I do not work for VM, but I would. It is just a Job.
I would also make websites for them, because the job never seems to require the website to work.
Read or Not ....
