  • 6
Message 1 of 4 (612 Views)
Broadband running very slow, and intermittent.
Hi all, my 30mb? broadband has been running very slow (average around 2mb) for a few months now and the service is very intermittent, cutting out regularly during downloads.  I have spoken to VM who tell me this is due to work going on in the area, but neigbours are not having the same issue and the work started only a month ago.  I did request an engineer but was told that this would be refused while the work is ongoing.
My stats are
Startup Procedure
ProcedureStatusComment
Acquire Downstream Channel459000000 HzLocked
Connectivity StateOKOperational
Boot StateOKOperational
Configuration FileOK
SecurityEnabledBPI+
Downstream Channels
Lock StatusModulationChannel IDMax Raw Bit RateFrequencyPowerSNRDocsis/EuroDocsis locked
LockedQAM25621255616000 Kbits/sec459000000 Hz2.2 dBmV35.7 dBHybrid
LockedQAM25620955616000 Kbits/sec435000000 Hz2.1 dBmV34.8 dBHybrid
LockedQAM25621055616000 Kbits/sec443000000 Hz2.2 dBmV35.4 dBHybrid
LockedQAM25621155616000 Kbits/sec451000000 Hz2.1 dBmV35.4 dBHybrid
UnlockedUnknown00 Ksym/sec0 Hz0.0 dBmV0.0 dBUnknown
Upstream Channels
LockedATDMA120480 Kbits/sec45800000 Hz43.0 dBmV
Downstream(0)
SFID4352
Max Traffic Rate33330000 bps
Max Traffic Burst3044 bytes
Mix Traffic Rate0 bps
Primary Upstream Service Flow
Upstream(0)
SFID4351
Max Traffic Rate3333000 bps
Max Traffic Burst8160 bytes
Max Concatenated Burst8160 bytes
Scheduling TypeBest Effort
Current System Time:Tue Dec 06 21:46:39 2011
  • 5.09K
  • 97
  • 285
Message 2 of 4 (579 Views)
Re: Broadband running very slow, and intermittent.
Hi blokeybob,
We do have an open fault on your local chassis which is linked to high upstream utilisation and this will be the likely cause of the problems you are reporting. Fault reference is F001818702 and we are currently waiting for our Planning team to publish an estimated fix date. Please bump this thread in 3-5 days time and we will check for updates.
We're sorry for any inconvenience this may be causing.
Regards,
Ray Miranda
Help & Support Forum Team
If someone's helped you out say thanks by clicking on the Kudos Star. If someone's solved your problem, why not mark their message as a Helpful Answer? You can also help other users find useful posts by Tagging them with keywords.
If you are new to the forum, please remember to search the forum before posting your question. Please don't send private messages directly to the forum team unless they ask you to, post your issue to the forum first.
Got a problem? Check for faults online with our new service status and fault checker
  • 6
Message 3 of 4 (561 Views)
Thanks ray....oh and bump!
  • 2.09K
  • 6
  • 100
Message 4 of 4 (539 Views)
Hi blokeybob
Ticket F001818702 currently has an estimated fix date of 25th January 2012. We're very sorry for the inconvenience this has caused.
Mark_Wilco
