Just joined
thuuotirec
Random disconnects
I see some other people have this problem but could not see the solution.  Please could you help.  My Modem/router will at random intervals disconnect (every hour approximately).  The disconnects seem much more frequent during the day and less frequent in the evenings.
During a disconnect The "virgin" light on the front turns from solid blue to red, then to flashing blue, then the modem/router will reconnect itself and continue working normally without my intervention.
The SNR and power levels seem to be within your limits (see below), also I have copied the even logs - but the disconnects are not shown on the event log.
Please will you help, and if it is a faulty modem, please could you send a replacement?
Connection
Startup Procedure
ProcedureStatusComment
Acquire Downstream Channel298750000 HzLocked
Connectivity StateOKOperational
Boot StateOKOperational
Configuration FileOK
SecurityEnabledBPI+
Downstream Channels
Lock StatusModulationChannel IDMax Raw Bit RateFrequencyPowerSNRDocsis/EuroDocsis locked
LockedQAM2562655616000 Kbits/sec298750000 Hz-0.1 dBmV41.0 dBHybrid
LockedQAM2562555616000 Kbits/sec290750000 Hz0.4 dBmV41.4 dBHybrid
LockedQAM2562955616000 Kbits/sec306750000 Hz-0.6 dBmV40.6 dBHybrid
LockedQAM2563055616000 Kbits/sec314750000 Hz-1.0 dBmV40.5 dBHybrid
UnlockedUnknown00 Ksym/sec0 Hz0.0 dBmV0.0 dBUnknown
Upstream Channels
LockedATDMA220480 Kbits/sec35800000 Hz45.5 dBmV
Downstream(0)
SFID2414
Max Traffic Rate33330000 bps
Max Traffic Burst3044 bytes
Mix Traffic Rate0 bps
Primary Upstream Service Flow
Upstream(0)
SFID2413
Max Traffic Rate3333000 bps
Max Traffic Burst8160 bytes
Max Concatenated Burst8160 bytes
Scheduling TypeBest Effort
Current System Time:Fri Dec 30 12:55:21 2011
TimePriorityDescription
Tue Dec 27 21:38:29 2011 Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Wed Dec 21 21:29:30 2011 Critical (3)DHCP FAILED - Requested Info not supported.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Wed Dec 21 21:29:21 2011 Critical (3)No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.0;CM-VER=3.0;
Time Not EstablishedCritical (3)DHCP FAILED - Requested Info not supported.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.0;CM-VER=3.0;
Time Not EstablishedCritical (3)No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.0;CM-VER=3.0;
Time Not EstablishedCritical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.0;CM-VER=3.0;
Time Not EstablishedCritical (3)SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.0;CM-VER=3.0;
Time Not EstablishedCritical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.0;CM-VER=3.0;
Time Not EstablishedCritical (3)DHCP FAILED - Request sent, No response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.0;CM-VER=3.0;
Please use plain text.
PatrickF
Re: Random disconnects
Hi thuuotirec,
I have sent you a Private Message. We'll be happy to progress things for you once we have received your reply.
Kind Regards,
Patrick
